July 5, 20224 yr comment_293994 Recently I've been helping my nephew make a bunch of cutting boards to help fund his first semester in college. Basically a lot of tablesaw, jointer, and surface planer work. During the midst of it all the dust collector just quit working all of a sudden. I did basic troubleshooting. The unit powers on but there is no suction. There are no clogs. It's not full. No obvious leaks or tears in the hoses. Could it be the impeller? Very similar to this model.... https://www.rockler.com/dust-right-reg-wall-mount-dust-collector-650-cfm .40 Edited July 5, 20224 yr by forty_caliber Report
July 5, 20224 yr Popular Post comment_294005 Remove the hose from the collector body and turn it on. You should be able to see the impellor moving. It could be slipping on the motor shaft or have broken blades. Report
July 5, 20224 yr Popular Post comment_294009 If as you say there are no clogs anywhere then it almost has to be an impeller related problem. Report
July 5, 20224 yr Popular Post comment_294014 Great to have you posting again Forty...been missing you. As others have noted, my quess is the impeller slipping on the motor shift. Sheared key perhaps??. Report
July 5, 20224 yr Popular Post comment_294032 4 hours ago, Grandpadave52 said: Great to have you posting again Forty...been missing you. As others have noted, my quess is the impeller slipping on the motor shift. Sheared key perhaps??. That was my thought....sheared key. Report
July 5, 20224 yr Author Popular Post comment_294034 Thanks for all of the responses. I'll take a look. Hopefully, I can get parts for it. .40 Report
July 6, 20224 yr Popular Post comment_294049 There may be a clog right at the inlet. The cross hairs are known for catching shavings and clogging things up. I cut them out of mine. Report
August 31, 20224 yr Author Popular Post comment_297759 Just a quick update. I found a "cakes" of accumulated dust inside the housing. I broke that up with a screwdriver and got it working again. Kind of a PITA, but after a dozen years use I guess that's to be expected. .40 Report
August 31, 20224 yr comment_297760 42 minutes ago, forty_caliber said: Just a quick update. I found a "cakes" of accumulated dust inside the housing. I broke that up with a screwdriver and got it working again. Kind of a PITA, but after a dozen years use I guess that's to be expected. .40 Hey forty, just curious, do you or have you cut a lot pine? Overtime pine will cake like that. Report
August 31, 20224 yr comment_297761 57 minutes ago, forty_caliber said: Just a quick update. I found a "cakes" of accumulated dust inside the housing. I broke that up with a screwdriver and got it working again. Kind of a PITA, but after a dozen years use I guess that's to be expected. .40 Glad you got it going and was a relatively (at least inexpensive) easy fix. Appreciate you updating the thread. It might help others in the future. Report
August 31, 20224 yr comment_297763 1 hour ago, forty_caliber said: Just a quick update. I found a "cakes" of accumulated dust inside the housing. I broke that up with a screwdriver and got it working again. Kind of a PITA, but after a dozen years use I guess that's to be expected. .40 By the wheel or at the outlet chute? Report
August 31, 20224 yr Author comment_297765 33 minutes ago, HandyDan said: By the wheel or at the outlet chute? In the wheel, enough that the impeller had worn a grove in the sawdust cake in some spots.. .40 Report
August 31, 20224 yr Author comment_297766 1 hour ago, John Morris said: Hey forty, just curious, do you or have you cut a lot pine? Overtime pine will cake like that. Plenty of pine over the years. That and the humidity here were contributing factors for sure. .40 Report
