November 4, 20215 yr comment_274203 Can someone tell me which is the correct way to use this tool? Flute up or down on the tool rest? Report
November 4, 20215 yr comment_274211 I made one from a planer blade and used it flute up . I have not tried flute down it just seemed intuitive to me -up. Even tho I did thin the back it gets grabby when you get more than 1 inch in . The cut is wonderful and looks just like you planed it with a skew. Report
November 4, 20215 yr comment_274217 For some reason there is no picture. I have a Sorby and it is used flute up. The ridges of the flute create the sharp points that score the wood fibers on the way in creating the cut smooth. If you use it down you will ruin those edges on the tool rest. I love mine. Edited November 4, 20215 yr by HandyDan Report
