October 30, 20215 yr Popular Post comment_273733 I spent a little time turning this monkeypod bowl. Rough turned due to high moisture content. Meter showing 30-35%. Packed in shavings to dry for now. It's supposed to be a Christmas present and I'm hoping it will dry out enough to finish by then. This piece of wood turned really well. Has kind of a spicy smell, but not overpowering or bad. Dense tight grain with large pores. Seeing minor end grain tear out and some fuzzies. Shear scraping took care of that easily. .40 Edited October 30, 20215 yr by forty_caliber Report
October 30, 20215 yr Popular Post comment_273736 1 minute ago, lew said: Sweet! Is your steady rest home made? Looks like that might be the One Way bowl steady. Report
October 30, 20215 yr Author comment_273737 7 minutes ago, lew said: Sweet! Is your steady rest home made? 5 minutes ago, Fred W. Hargis Jr said: Looks like that might be the One Way bowl steady. Spot on. One Way's bowl steady. Used in the front for interior hollowing, can be flipped 180 for working on the exterior. Heavily made, almost eliminates vibration and chattering. .40 Report
October 30, 20215 yr comment_273738 Just now, forty_caliber said: Heavily made, almost eliminates vibration and chattering. Thanks! Report
October 30, 20215 yr Popular Post comment_273755 2 hours ago, lew said: Sweet! Is your steady rest home made? They are easy to make. Find a steady rest and a piece of square tubing that fits inside. Drill holes and mount wheels. The square tubing makes for easy wheel mounting and still holds nice in the round hole. I also found a set of scooter wheels that work nicely too. They have appx. 4.25 dia. I like them when doing spindles the smaller diameters fit deeper onto the wheels so this two wheel set up works well. Easier to set up than my three wheel steady. Report
October 30, 20215 yr Popular Post comment_273764 Looks good . I do not think it will dry in time to finish. If you have another blank try turning to finish I thing you will be surprised at the result. Not a perfect round, but none are really anyway. Just try it on some extra wood of any species I think you will be pleasantly surprised. Report
October 31, 20215 yr Popular Post comment_273860 20 hours ago, HandyDan said: They are easy to make. I think I can use my psychedelic steady with one side removed for this! Report
October 31, 20215 yr comment_273876 3 hours ago, lew said: I think I can use my psychedelic steady with one side removed for this! That is pretty neat. Now when does it become a reality? Report
October 31, 20215 yr Popular Post comment_273879 22 minutes ago, Gerald said: That is pretty neat. Now when does it become a reality? IMG_0977.mp4 Report
December 12, 20214 yr Author Popular Post comment_277879 A couple of weeks ago, I took the MP bowl out of the shavings bag and carried it inside. Moisture meter was reading at that time was about 25% down about 10% from when it was roughed out. I put the blank on a shelf above the hot water heater. Checked on it today, and found that it was running about 10% moisture. Will have to remember this trick when I want to hurry one along. Drying done and done. Finished turned this morning. .40 Report
December 12, 20214 yr Author comment_277885 18 minutes ago, HandyDan said: Beautiful! How was the Monkeypod to turn and sand? It wasn't too bad. When wet, it tended to leave fuzzies behind. More tear out type issues dry. Sheer scraping and delicate light passes with a negative rake scraper took care of the problem pretty easily. Sanding was very easy and quick. .40 Report
December 13, 20214 yr comment_277895 4 hours ago, forty_caliber said: A couple of weeks ago, I took the MP bowl out of the shavings bag and carried it inside. Moisture meter was reading at that time was about 25% down about 10% from when it was roughed out. I put the blank on a shelf above the hot water heater. Checked on it today, and found that it was running about 10% moisture. Will have to remember this trick when I want to hurry one along. Drying done and done. Finished turned this morning. .40 Nice! Looks like you got the laser dialed in, too. Report
December 13, 20214 yr comment_277907 Excellent job for "monkeying" around. Love the final look and finish. Customer should be ecstatic. Report
