Posted
If you could only have one, a thickness planer or drum sander which would you choose?
  • Like 2
Posted
That is a tough one. The planer is faster at removing material but can be limited in width- unless you are willing to spend big bucks. Also most bench top planers can’t get much thinner than between 1/4 to 3/16” without causing some species to split/shatter unless they have a helical head which can really jump up the price.
Open end thickness sanders can do wider material, thinner material but are very slow removing material.
I use my planer a lot more than my shop made thickness sander.
Posted
Hard to answer. I got the planer first and had done the job of the sander by hand for years. THEN wife got me the drum sander for Christmas. I use it for tops but also to size small pieces for boxes or dividers. It is hard to separate the two but I would also say the planer is most valuable. This is true especially is you use rough sawn lumber. Now if you do lots of tables or case work maybe not.
Posted
I agree with the others about purchasing the planer first.  For a temporary solution for a drum sander, you could rig something to use on the lathe.  A piece of 6" schedule 40 or thicker to make a drum sander.  To fill the pipe, use wood turned to fit inside interlayered with stiff stuff.  I think that may make it rigid enough to pass as a good drum sander until you can purchase one.  And, I would not turn the lathe any faster than 600 rpms while sanding.
  • Like 3
Posted
I have to agree. I would get the planer first. Being able to get all your stock to a uniform thickness is important. You can accomplish the surface sanding in other ways but you can’t really surface wood in the rough with a surface sander.
Paul
Posted
The planer will almost certainly get more use in most shops. Some years ago I bought a second hand DS from a colleague with no idea what I would do with it. It actually got a fair amount of use, but that declined over the years and I sold it I've since replaced it, but the new one has also seen very little use. They aren't finishing sanders, and it sometimes takes more work to clean the marks from a DS than those from a planer. Steve made an excellent point...they (DSs) produce mountains of very fine dust, and it takes a capable DC to catch it all and contain it.
Posted
The planer without a doubt.
I agree with all the above. I had a Performax that I used rarely, to the point it wasn't worth the real estate it took up in the shop, I sold it.
That's just me though, obviously I didn't think the original purchase of the sander all the way through.
Posted
21 minutes ago, RustyFN said:
Thanks everybody. Planer it is.
Good choice Rusty, I remember when I was pondering the same thing before I had either, and I asked the same question of folks here as I recall. I had originally thought I was going to purchase the sander first, or just the sander, because I was thinking, heck it'll remove wood too right? So why not double duty it as a sander/planer, then as I learned more from the folks here just what the limits are of the sander, I realized the planer had to come first, because material removal was more important to me than sanding.
So, what kind of planer you looking to get?
Posted
I have to add one more piece of equipment for the things I build to make it three pieces of very important machines I want to have available in my shop all the time.
  I went to a wood working shop that has been going for about 70 years now and ask them the same question you asked about 22 years ago......Planer, joiner and an open ended drum sander only then they said drum sander and I guess they had not come along with the open ended models back then ?.... It really depends on what you want to make of yourself working with wood. My woodworking starts with the scroll saw and I know lots of guys that only have a scroll saw and make lots of things but I use lots of wood that has to be edge glued to be wide enough to start with so the three pieces of machinery after the usual wood working things and I would start with getting the planer first then the joiner then the drum sander.
  • Like 2
Posted
I have seen this Cutech around and it seems to have good reviews.  Might be considering that to upgrade from my Ryobi 10 1/2 inch.
  • Like 4
Posted
12 hours ago, Smallpatch said:
Rusty I noticed while looking it over it comes with hss bits and is up gradable to tungsten so do go with the better bits.
The link I posted should be with the carbide upgrade.
  • 2 weeks later...
  Only 75 emoji are allowed.
