May 26, 20215 yr comment_266223 I'm building a lumber rack from 2X4s and 3/4" EMT. I need to drill 3/4" holes at a 5° angle on the edge of an 8' 2X4. They need to start 1' from the end and go up in 1' increments. My problem is that the holes need to angle upward along the length. As you know, our table only tilts on one axis. In the DP mode, that's front and back. Am I missing something? Report
May 27, 20215 yr comment_266227 Not sure I completely understand, but it sounds like you could use the table for one direction and a wedge for the other. .40 Report
May 27, 20215 yr Popular Post comment_266228 Horizontal boring. Clamp a straight edge at your 5* angle on the table and slide the 2x4 along it to each hole position. Set the straight edge so the drilled edge of the 2x4 is right at the edge of the table. You'll probably need some help hanging on to the 2x4 but it won't take long to get all your holes knocked out. Report
May 27, 20215 yr Author comment_266239 11 hours ago, Headhunter said: Horizontal boring. Clamp a straight edge at your 5* angle on the table and slide the 2x4 along it to each hole position. Set the straight edge so the drilled edge of the 2x4 is right at the edge of the table. You'll probably need some help hanging on to the 2x4 but it won't take long to get all your holes knocked out. That's a plan! Hadn't considered horizontal boring. Roller stands will work as the third hand. Thanks a lot, Tony. Report
May 27, 20215 yr comment_266255 Glad to be of assistance. Remember - No Pictures - Didn't Happen! Finished product, of course. Report
May 27, 20215 yr Author Popular Post comment_266261 Gotta help my son build some gates this weekend. Oughtta get to that lumber rack build Monday, though. Then, pics. Report
May 28, 20215 yr comment_266270 Excellent suggestion that works. Gene, if you have one of these, you can clamp it to your fence. https://www.rockler.com/universal-fence-clamps-with-clamp-it-square Glad someone else has one of these sweet machines. I am working on this old house and taking much of my time. Hope to return sometime soon. Report
May 28, 20215 yr Author comment_266278 Thanks @FlGatorwood. Got a couple sets of those. But, God knows where they are. I'll limp along with 2by stuff. Report
