Posted
For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project"
Additional What's It Rules
  • Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source.
  • An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc...
Ok ladies and gentlemen, we now have our "What's it" live and ready!
    Project Details
    The information provided hereon is all the information that is provided, no further information on this item will be added.
    156-9  Someone emailed: “Attached is a photo of a solid brass, 12-inch gauge I recently found. It has a scale that is divided into tenths of an inch and is adjusted using a gear rack drive. There are no markings that would help to identify the gauge’s origin and the numbers are hand-stamped. Anyone have any ideas as to the intended use of this item? It probably originated in New England, since that is where it was found.”
    • Like 3
    Posted
    2 hours ago, Gerald said:
    Looks like a measuring and marking gauge and the funny thing is I think I have seen this somewhere.
    Did we do this one before?
    • Like 3
    Posted
    This one's simple.
    It's a slide rule(r)
    • Haha 3
    Posted
    Off Topic posts hidden, now how about back to that brass ruler contraption? :)
    • Like 1
    • Haha 2
    Posted
    Wasn't there a Picture Framer's Miter Box that used this to set how long a piece was set in the cutting area ?
    Thinking either a Goodell Pratt Co. or...a Stanley?
    Basically... a length stop in a mitre box....tab that sticks up for the wood to rest against.  Ruler part would be sitting down in the groove milled for it, in the metal bed.   Was later replaced with a wood ruler....
    You could "dial" up the length of cut....leave it sit there for the matching cuts....Gear drive allows to fine tune the cut.
    • 2 weeks later...
    Posted
    Congrats!   Did i miss the end of January and start of Feb?  :WonderScratch:
    • Like 1
    • Haha 1
    • Thanks 1
      Only 75 emoji are allowed.
