Gerald Posted October 2, 2020 Report Posted October 2, 2020 Lots of options but look at the Laguna 1216 Quote
AndrewB Posted October 2, 2020 Author Report Posted October 2, 2020 Well if I wasn't going to waste anything Id probably pop the motor off of my wen lathe and use that instead of spending extra money on another lathe. Quote
Larry Buskirk Posted October 4, 2020 Report Posted October 4, 2020 On 10/2/2020 at 2:06 PM, Gerald said: Larry a Reeves has two sets of split pullies. It does not work with fixed pullies. If you change to fixed then will only have one speed ..I'm used to the "OLD" Delta Reeves Drive where they used a fixed, and variable pitch pulley. Haven't seen any of those newfangled double variable pitch pulley setups. Things were simpler when my machines were made 60-90 years ago. Gerald and p_toad 1 1 Quote
RustyFN Posted October 5, 2020 Report Posted October 5, 2020 You can buy a inverter duty motor and VFD for around $240. Quote
