August 24, 20206 yr comment_240121 @Jim from Easy Wood Tools provided this article just published in the American Association of Woodturners "Woodturning Fundamentals" August issue. It is co-authored by Chris Caliendo from Easy Wood Tools. What is Negative Rake by Chris Caliendo.pdf The publication also has an extensive compare/contrast article on carbide turning tools- including Easy Wood Tools. Report
August 24, 20206 yr comment_240133 Very informative, think I’m gonna print that one and post it in the shop. Report
August 24, 20206 yr comment_240134 Here is another interesting article from the same issue American Woodturner WF0903-2020Carbide Tools History.pdf Report
August 24, 20206 yr Author comment_240141 1 hour ago, Jim from Easy Wood Tools said: Here is another interesting article from the same issue American Woodturner WF0903-2020Carbide Tools History.pdf 325.51 kB · 4 downloads Thanks!! Report
August 29, 20206 yr comment_240639 It seems from the first article, that the carbide tools are basically scrapers however, they can be rather aggressive. Got to get busy and play with this new set that I was so graciously given. I did try the rougher for a few minutes and I like it, but I will be testing each soon. Thank you for the articles, Jim and Lew. This is good information. Also, thanks for the second article. I was considering trying tips from another company to see how they compared, but after reading the second article, I think I will stay with the company who made the tools as their tips should fit perfectly each time. Will be investigating more as I think I need to have a supply of cutters on hand for this Christmas season. I have lots of turning lined up. Thanks, again, Jim for posting this neat information. Edited August 29, 20206 yr by FlGatorwood Report
September 1, 20206 yr comment_240912 On 8/28/2020 at 9:44 PM, FlGatorwood said: Thanks, again, Jim for posting this neat information. You are very welcome sir... Hoping you will find it useful. Cheers Report
