July 21, 20206 yr comment_236068 7 minutes ago, Larry Buskirk said: In that case it might be easier to use an easy out. You might have to grind the tip off to fit the screw. Here's the screw, Larry. Report
July 21, 20206 yr comment_236069 1 minute ago, Gene Howe said: Here's the screw, Larry. Might also be able to pound an allen tip into the head. Report
July 21, 20206 yr comment_236098 This reminds me of trying to get a screw out of my wife's Singer Featherweight sewing machine. Slotted head that had been stripped and couldn't get it open to lube the gears. I took it over to a friend's house that is more into machine stuff. He had to pound it out with a cold chisel. Then we find out it's a 6-40 (fine thread) that no hardware store carries. So I had to order online and had to buy a bag of 25 or so. Fortunately, allen (hex) drive. Then it was just a trifle long, so back to my friend's house where he had a 6-40 tap to thread another 1/8" deep. If anyone needs one for the access plate cover on the top, let me know. I have a few extra. Report
July 21, 20206 yr Author comment_236099 5 hours ago, Gunny said: I have 2 of same set. One at work, one at home. Thanks, I never knew there was so many and for sure didn't know HF had that kit. I don't get into many of those situations much anymore, but sometimes $10 is a small price for something that will fix your problem. Fix it before you wreck it trying Report
July 21, 20206 yr comment_236102 46 minutes ago, Ron Altier said: Thanks, I never knew there was so many and for sure didn't know HF had that kit. I don't get into many of those situations much anymore, but sometimes $10 is a small price for something that will fix your problem. Fix it before you wreck it trying I saw it online looking for something else. Thought for that price I can use it once and get myself out of a jamb and make out. Since then have used alot more than I thought. We take all kinds of stuff apart at work. Report
July 22, 20206 yr comment_236129 When Gunny retires, he can sell that set of tools at his house and have a very nice retirement. Yes, my first thought was use an easy out. I have a set of them and they are very handy. I use a center punch to initiate the hole, then use the Shopsmith as often as I can to get a pretty precise bore. It works most of the time. Report
July 22, 20206 yr comment_236235 That looks a bit sad. I didn't see a pentalobe and some of those spline looking ones on kmealy's chart aren't the old spline tools i recall. someone always has a better idea. Report
July 22, 20206 yr comment_236241 48 minutes ago, p_toad said: someone always has a better idea. Too make things harder for do it yourselfers. Report
