February 26, 20206 yr comment_219845 Many years ago I made this 12" dia embroidery hoop. To use it, set it between your legs using your leg weight to hold it in place. It has 3 adjustable joints and three finger bolts to hold it in place. Over the years the friction hold points of the adjustments have become too smooth and it slips. If I roughen up the friction hold points, they will soon be smooth again. What can I do to make these adjustments hold? I've tightened them VERY tight by hand, but they still move. I've thought about very thin washers with rough surfaces, don't know where I'd find something like that. Any thoughts would be appreciated. Edited February 26, 20206 yr by Ron Altier couldn't get pictures to download Report
February 26, 20206 yr Author comment_219847 I had a lot of problems getting the pictures to download. Finally it accepted them. Report
February 26, 20206 yr comment_219848 How about make a washer from some self stick sand paper? Or add some finish and throw some sand on before it dries. Report
February 26, 20206 yr comment_219852 Self stick sandpaper like Dan suggested works good. I cut them to size like a washer on both sides. Used 80 grit sandpaper. Report
February 26, 20206 yr comment_219855 I actually would go the other way around. Put metal washers on the outside to keep the metal bits from sinking to deep to be tight. With the metal washer on the outside the clamping pressure will surely hold tight. If not then yes some self made sandpaper washer are the way to go but will be temporary. Report
February 28, 20206 yr comment_219946 Green felt paper. Green very thin felt with sticker paper on the back. Available at craft stores. Two pieces inside and two pieces outside with the green felt facing each other will give you the friction you need. Report
