Posted
For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project"
Additional What's It Rules
  • Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source.
  • An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc...
Ok ladies and gentlemen, we now have our "What's it" live and ready!
Project Details
The information provided hereon is all the information that is provided, no further information on this item will be added.
  • Like 2
Posted
There are gradient marks on the other side but of course a good picture of that end isn't available.  Must be some sort of adjusting tool for ????????????
  • Like 2
Posted
That's along the lines of my thoughts also.  A type of micrometer.
  • Like 2
Posted
Maybe just a gauge, to let you know what size bolt and/or nut to use....and what size wrench to grab.....Like when one was replacing broken boiler plate bolts when doing a service call at a house.  Can also use the "rounds" to line up the bolt holes.
  • Like 3
Posted (edited)
It looks a sizing tool for a manufacturing process.You insert the hex end in a base unit hex cavity, until you have a proper size fit and then pull a top part down on it. Then turn the top of this tool until you have a proper distance between the two. Different sizes of product require distances.
Edited by Ron Altier
sp
  • Like 2
Posted
Wouldn't surprise me if it is motorcycle related.  Lots of different suspensions and adjusting tools out there.
Posted
Kinda reminds me of an alignment tool to position a clutch plate.
  • 2 weeks later...
Posted
Those are usually round tools unless they are a direct fit and splines are added.
  • Like 3
  • 3 weeks later...
Posted
It's a plug remover for removing plugs.  Used with a pipe wrench and extender for removing caps off pipes, steam plugs,sewer plugs, large boiler plugs. Don't forget the torch to heat it up.
  • Like 2
Posted
Never saw a plug that was deep enough to accommodate the steps of this tool for the larger sizes.
  • Like 2
Posted
Mostly big industrial. Stuff homeowners rarely see.
  • Like 2
Posted
Winner
@p_toad has been selected as this months MWTCA Membership recipient.
Since a verifiable answer was never arrived at for this item, we went to random draw.
Award
Peter, for your participation you have won a 2020 Calendar Year membership into the MWTCA.
Please Private Message me your contact info, shipping address, spouse or significant others name (if applicable).
Thank you all for your participation!
Links
Gristmill Magazine Sample
the gristmill
Posted
You will enjoy the prize.  Congrats Pete!
  • Like 3
  • 2 weeks later...
Posted
Did my name break this and now we don't get a January whatzit?  :WonderScratch:
Or did it get posted and i can't see it?  :BitingNails:
  Only 75 emoji are allowed.
