Posted
I lost my manual for my craftsman battery operated chain saw mod #900-98023. I need to know how to advance the chain so I can sharpen. My gas chain saw I just move by hand and sharpen. The chain won't advance like my gas saw. Does anyone have one of these saws who knows how to move the chain?
Preston
Posted
Thanks Larry. I read the manual and couldn't find what I needed. I am trying to find out how to sharpen the blade while it is still on the saw. On my gas chain saw I cam move the blade forward or backward and sharpen. The blade on the battery operated won't budge either way. I have to take it apart and move the blade and sharpen. Very time consuming.
Preston
Posted
Preston,
I just took a look at the manual, and it states that there is a motor brake that gets engaged when the trigger is released.
Try pulling the trigger while trying to rotate the chain. The manual doesn't state if it's a mechanical or electronic brake.
Posted
Larry:
Thanks for all the trouble I'm putting you through. I tried the trigger and the blade won't move. Sorry.
Preston
Posted (edited)
Can you mark the chain, reinstall battery and try to stop it at a different point, remove battery sharpen and repeat process.   Besides the brake, if it is a worm drive it will be hard to have the chain drive the motor.  Remember the gas saw has a centrifugal clutch, the electrics don't.  Roly
Edited by Roly
typo
  • Like 2
Posted
Roly:
You may have something there Roly. I will give it a try tomorrow morning when it is cooler. I'll let you know for sure. I have been marking with a black marker pen. Thanks again.
Preston
Posted
Roly:
It worked. I marked one cutter and moved the chain forward. It took a while but it got the job done. I went to a sears store and they didn't have an answer. They showed me the manual that Larry showed. I got the saw sharpened. I thank everyone  for all the help.
Preston
  • Like 2
  Only 75 emoji are allowed.
