July 9, 20197 yr comment_195522 I inherited this beauty from my uncle, who inherited it from my grandfather, who I believe bought it new. All i know of it so far is it is a Duro desktop band saw. I am planning to do a total restoration on it, and need some advice on how to approach prepping the cover for primer and paint. I may have access to a soda blaster to gently remove the small amount of paint, and surfact corrosion, but if not i need to know how to properly removed the age without damageing the cast iron. I want to return make this back into a working piece, and so will be doing a full disasemble and repair/replacment of needed parts. Does anyone know of a parts guide or owners manual that may exist for these old units? Any advice would be greatly appreciated. Report
July 10, 20197 yr comment_195549 Welcome aboard Chris, glad to have you here - and posting up pics to boot! Can't help you with the saw, but hopefully @Larry Buskirk might chime in with some info. If that cover is cast iron, I would think a regular sandblaster would be fine. How much does that thing weigh? When you talk about a restoration, do you mean original type and color of paint and all? Report
July 10, 20197 yr comment_195582 Hi Chris, Welcome to The Patriot Woodworker. Your Duro Band saw dates from the late 1940's to early 1950's. I found a few pieces of literature, but will need a bit more information to give you links to what I found. There were a few models (sizes) of this style saw available ranging from a 9", 10", and also a 15". So if you could measure from the rear arm to the blade so I know what size the saw is, I'll post the proper links that I managed to locate. If you could also provide a photo of the back side of the saw I'll be able to tell if this might be a wood/metal saw. I believe the covers are made of Zamak which is a pot metal alloy that would not take sandblasting, a better approach might be to use paint stripper. Report
July 16, 20197 yr Author comment_196154 Cal, It weighs a good bit, i would estimate around 40-50 LBS and is not quite waist height. Quite a compact piece of machinery. I would really love to restore it to original colors and put it in my garage shop. Because it was my grandfathers, i really want to make it whole again, and i also love the art-deco style details on it. I think it could be quite beautiful when finished. Report
July 16, 20197 yr Author comment_196155 Thank you Larry! I will get the measurements and pictures this evening after work and get them uploaded. I appreciate your advice on the stripper rather than sandblasting. I dont want to do anything that would risk marring the finish. Report
July 21, 20197 yr comment_196596 As you go about the restoration take pictures, lots of them. Then post and show your progress , issues, and successes. Report
October 15, 20197 yr comment_205280 I just bought one veey similar and was wondering if you finished your project or not Report
