kmealy Posted June 17, 2019 Report Posted June 17, 2019 Was amused by this manufacturer's description, and the wonderful warranty. The Hitachi 303761 6-Inch High Speed Steel Jointer Planer Blade for the Hitachi P12RA Jointer is made with high speed steel. It cuts through a variety of materials and does not dull or wear. This blade is designed to withstand repeated use without shattering or bending. The high speed steel is exceptionally strong and reinforces the cutting edge of this blade. This product is especially designed for the Hitachi P12RA Jointer and comes in 1-pair set. This product is perfect for storing in your garage or storage shed for convenient replacement parts. The Hitachi 303761 6-Inch High Speed Steel Jointer Planer Blade for the Hitachi P12RA Jointer is warranted to the original purchaser to be free from defects in materials and workmanship for a period of 30-days from the original purchase date. Every Hitachi accessory is designed to the highest standards and is rigorously tested for both performance and durability. HARO50, Gunny, lew and 1 other 2 2 Quote
Popular Post Gene Howe Posted June 17, 2019 Popular Post Report Posted June 17, 2019 I don't even own a jointer but, that blade description makes me want one just so I could get those. lew, HARO50, Artie and 3 others 6 Quote
HandyDan Posted June 17, 2019 Report Posted June 17, 2019 Well that's a lot of smoke. Gunny, HARO50, Gene Howe and 1 other 4 Quote
kmealy Posted June 17, 2019 Author Report Posted June 17, 2019 20 minutes ago, HandyDan said: Well that's a lot of smoke. and mirrors? HandyDan, HARO50, Gunny and 1 other 4 Quote
Popular Post Gene Howe Posted June 17, 2019 Popular Post Report Posted June 17, 2019 After some reflection, it becomes clear that you can't blow mirrors into the same orifices smoke goes. Larry Buskirk, FlGatorwood, HARO50 and 2 others 5 Quote
Gunny Posted June 18, 2019 Report Posted June 18, 2019 10 hours ago, Gene Howe said: After some reflection, it becomes clear that you can't blow mirrors into the same orifices smoke goes. I have learned from the master!!! Artie, Gene Howe, HARO50 and 1 other 4 Quote
FlGatorwood Posted June 18, 2019 Report Posted June 18, 2019 I have the Shopsmith joiner. It is a wonderful tool on woods. And, yes, I always use the guard. I can imagine what it would do to a hand. HARO50 and Artie 2 Quote
Gunny Posted June 19, 2019 Report Posted June 19, 2019 5 hours ago, FlGatorwood said: I can imagine what it would do to a hand. Very scary indeed. And yet some idiot has stuck his hand inside one, because it seemed like a good idea at the time...…... HARO50 1 Quote
Artie Posted June 20, 2019 Report Posted June 20, 2019 On 6/18/2019 at 4:06 PM, FlGatorwood said: I have the Shopsmith joiner. It is a wonderful tool on woods. And, yes, I always use the guard. I can imagine what it would do to a hand. I have one, haven’t used it yet But soon I will work up to that. HARO50 and Gunny 2 Quote
Gunny Posted June 20, 2019 Report Posted June 20, 2019 1 hour ago, Artie said: But soon I will work up to that. Tomorrow is calling. Artie 1 Quote
Michael Thuman Posted June 20, 2019 Report Posted June 20, 2019 Old jointers with square heads could swallow a hand but properly used worked fine. Given their ability to cause human damage the round ones came out with no more the 1/16" of the blade exposed. That does limit your cut but also saves you. i had a knotty peice of wood that actually trashed a jointer knife when then destroyed the wood and the infeed and out feed tables and the guard. Thankfully I heard it hit and my hands were ahead of the line of fire as they are supposed to be when feeding material. Thankfully the damage to the metal bits was neglible and some sand paper properly applied fixed the deformed metal. The blade however was toast. Or ordered a new set of knives and only use carbide tipped and now can swap out up to two blades if they get chipped. Gunny 1 Quote
Michael Thuman Posted June 20, 2019 Report Posted June 20, 2019 I should note I have a DJ-20 8" jointer when correctly tuned has no snipe and in general is a joy to use. Gunny 1 Quote
