April 25, 20197 yr comment_188708 Ladies and Gents, I intend to spend time in the shop this summer. Time to tool up. I have a standard marking gauge, the kind with the spike on it. I don't like it much, it follows the grain. I see a lot of youtubers using a metal marking gauge with a rotary cutter on it. Who uses one of these, do you like it, and what brand do you recommend? Same question for saws. If I were buying a tenon saw or panel saw, what brands should I consider? Report
April 25, 20197 yr Popular Post comment_188713 I have the Lee Valley one (older) . I think they have updated it now but it does work very good and makes a good mark. Easy to match to a workpiece for size. Ok I looked at the new one and the change is an improved microadjuster. And boy they sure don't give those away but worth the price. Edited April 25, 20197 yr by Gerald Report
April 25, 20197 yr Popular Post comment_188739 You might try making your own,like I did. They use a knife made from an old hacksaw blade. Herb Edited April 25, 20197 yr by Dadio Report
April 25, 20197 yr comment_188744 you sure are ate up w/ talent and your execution is second to none Herb... Report
April 25, 20197 yr Popular Post comment_188753 2 hours ago, Stick486 said: you sure are ate up w/ talent and your execution is second to none Herb... Yeah, I make a bunch of them at a time, so I can use them once and then throw them away. Herb Report
April 25, 20197 yr comment_188760 20 hours ago, tony ennis said: I have a standard marking gauge, the kind with the spike on it. I would fix that by sharpening the point down to a cutting edge and it's less inclined to follow the grain and more likely to just cut a line (which is kinda what the rotary one does, but you can make your own do that without buying a new gauge...well, unless you really WANT one). Report
April 25, 20197 yr Popular Post comment_188762 1 hour ago, Dadio said: so I can use them once and then throw them away. I'm moving my trash can to your shop... Report
April 26, 20197 yr comment_188766 1 hour ago, Stick486 said: I'm moving my trash can to your shop... Me too !!!!!! Report
April 26, 20197 yr Author comment_188769 So, given the OT posts, is this thread done, and Lee Valley/Veritas is the answer for saws and marking gauges? Report
April 26, 20197 yr comment_188785 Tony, don't forget Lie Nielsen if you can spare a few bucks. I have both the tapered dovetail saw and the tapered carcass saw, I wish I could say that I actually have built a few projects with them but the reality is I have only used them in a couple warm up sessions. They handle beautifully, and of course the fit and finish is superb, the cut is tight and clean and quick! The tapered portion of the saw takes advantage of your natural sway when cutting, and prevents cutting below a mark or line at the opposite side of a board. I have tried it and it truly is a good design to have, the tapered end. Tapered Dovetail Tapered Carcass Best part is, "Made in the USA". Here is a great read on the advantages of tapered saws at Lost Art Press. Report
April 26, 20197 yr Popular Post comment_188804 3 hours ago, tony ennis said: and Lee Valley/Veritas is the answer for saws and marking gauges? For the marking gauge making one is worth the time and effort. My opinion only, and by no means a pro, possible an amateur but if you ask my ex then some French vocabulary comes to mind. Having seen Herb's design I shall endeavor to do 1 / 1000 as well and consider myself well off. He has them down to a science. Report
April 26, 20197 yr comment_188812 5 hours ago, tony ennis said: So, given the OT posts, is this thread done, and Lee Valley/Veritas is the answer for saws and marking gauges? John is right, I have those 2 saws too and you can't go wrong with them, I got them from Lee valley/Veritas. HErb Report
April 26, 20197 yr comment_188824 12 hours ago, tony ennis said: So, given the OT posts, is this thread done, and Lee Valley/Veritas is the answer for saws and marking gauges? You can't go wrong with Lee Valley. Report
April 27, 20197 yr Author comment_188865 Thanks folks. Unfortunately the Lie-Nielson saws are too rich for my blood. They are beautiful indeed. So looking at a Veritas carcass saw and Veritas micro-adjust marking gauge. Anyone have a promo code handy? Report
April 27, 20197 yr comment_188867 9 minutes ago, tony ennis said: So looking at a Veritas carcass saw and Veritas micro-adjust marking gauge. A great choice indeed Tony! Still beautifully engineered saws. I am sorry, no promo code attached to our community. Wish there were though! Report
