Popular Post DRAGON1 Posted April 18, 2019 Popular Post Report Posted April 18, 2019 Finally got the plane I ordered from veritas at the woodworking show. Alot of plane for 129.00 p_toad, John Morris, Cal and 3 others 6 Quote
Gene Howe Posted April 18, 2019 Report Posted April 18, 2019 Sweet little plane. Quite handy, I'll bet. Gunny and Cal 2 Quote
John Morris Posted April 18, 2019 Report Posted April 18, 2019 Very nice Mike, lovely plane, they sure do good work don't they! Did you have a specific project you are going to break it in with or is on standby? Cal 1 Quote
Popular Post DRAGON1 Posted April 18, 2019 Author Popular Post Report Posted April 18, 2019 Lol, I'm still on standby but new toys always get me thinking... Cal, HARO50, Gene Howe and 2 others 2 3 Quote
Popular Post John Morris Posted April 18, 2019 Popular Post Report Posted April 18, 2019 52 minutes ago, DRAGON1 said: Lol, I'm still on standby but new toys always get me thinking... Right there with ya Mike, we'll find a use for it, even if we have to create a whole project around it! Gene Howe, HARO50, Gunny and 2 others 5 Quote
tomp Posted April 20, 2019 Report Posted April 20, 2019 I've had one for a while, and it's perfect for trimming screw plugs flush with the surface - just keep it razor sharp and use with a sweeping motion as you feed into the plug. Use a flush-cut saw to trim off most of the projection, and the plane will take the rest, no need for sanding either. Cal and HARO50 2 Quote
DRAGON1 Posted May 14, 2019 Author Report Posted May 14, 2019 On 4/20/2019 at 7:36 PM, tomp said: I've had one for a while, and it's perfect for trimming screw plugs flush with the surface - just keep it razor sharp and use with a sweeping motion as you feed into the plug. Use a flush-cut saw to trim off most of the projection, and the plane will take the rest, no need for sanding either. I'm mostly going to use it for cleaning out glue from corners. I use a sharp chisel for reading the grain on plugs then chiseling them off. Cal 1 Quote
