April 7, 20197 yr comment_186083 I'm having trouble with my router Plunge Locking Lever not fully locking. There is nothing in the manual for repairing this is there a solution somebody can give me? Thanks Pat Report
April 7, 20197 yr comment_186092 1 hour ago, Pat Meeuwissen said: I'm having trouble with my router Plunge Locking Lever not fully locking. There is nothing in the manual for repairing this is there a solution somebody can give me? Thanks Pat In the diagram I see a screw at the end of the shaft that possibly can be tightened to stake up some slack caused by wear. Appears to be a hex headed screw. Look at the mechanism and see if this is indeed possible. Be my 1st place to look. Also it has a spring and some washers. For a diagram I looked on ereplacements.com. Report
April 10, 20197 yr Author comment_186524 It turns out that the locking lever can just be lifted forward and set down one notch back further on the large hexnut that captures it. Report
April 10, 20197 yr comment_186563 3 hours ago, Pat Meeuwissen said: It turns out that the locking lever can just be lifted forward and set down one notch back further on the large hexnut that captures it. The salesperson at the BB had issue with me asking could I take it apart and look at something. Good find, I was sure some adjustment for wear was possible. Report
