March 14, 20197 yr Popular Post comment_182495 From an internet series....decided to buy some extra hose.. Needed some glue, too. . And some plastic pipe and a few parts. I cut the 10' pipe down a bit, and then cut the cut-off into a few other parts... I now have some purple, sticky fingers, but...part 1 is installed.. Checked to make sure the hose will screw onto this. Pipe is 3/4" schedule 40..... OK, at the other end of the 8' pipe.. Is the "Hook" that will reach down into the gutter, while I stay on the ground....there is a cap at the end of the hook.. So, with the hose turn up full blast, this is now a sprayer....to wash the leaves and other junk down the gutter toward the down spout. May need to add some "grippy tape" for a handle... Might be safer than me walking around up on the roof....test dry when the weather improves... Glue and the hose were the "big ticket" items....we'll see how it works... Report
March 15, 20197 yr Popular Post comment_182518 Should work. Can also use to make a prank set up "sprinkler" for when those pesky salespeople or other undesirables come to the door. Report
March 15, 20197 yr Popular Post comment_182632 I have a feeling you will get wet also. You might want to give a little bend to the straight section to put it out in front of you. Roly Report
March 15, 20197 yr Popular Post comment_182634 14 hours ago, Woodbutcherbynight said: Should work. Can also use to make a prank set up "sprinkler" for when those pesky salespeople or other undesirables come to the door. A shotgun fully loaded and 10 pit bulls works. Report
March 15, 20197 yr Popular Post comment_182635 The shot gun will also clean out the gutter. Roly Report
March 16, 20197 yr comment_182691 10 hours ago, Roly said: The shot gun will also clean out the gutter. If the police come just tell them you were celebrating something. Report
April 2, 20197 yr Author comment_185430 Had the wrong end on the pipe...had to go back and get an adapter so a hose could be attached...Brain fart.. Report
April 2, 20197 yr comment_185432 17 minutes ago, steven newman said: Had the wrong end on the pipe...had to go back and get an adapter so a hose could be attached...Brain fart.. Those hurt...at least they don't stink. Report
April 3, 20197 yr comment_185474 4 hours ago, Grandpadave52 said: Those hurt...at least they don't stink. I dunno, my boss gets them and it stinks the rest of the day. Report
