February 28, 20197 yr comment_180323 I am making some hickory doors for cabinets with raised panels. I had my router bit sharpened and it did a good job, but the end grain needs to be sanded. How do you go about sanding the end grain on raised panels? Best regards, Ron Report
February 28, 20197 yr comment_180328 Double the grit number that you sand the long grain w/... Edited February 28, 20197 yr by Stick486 Report
March 3, 20197 yr comment_180807 I just sand it. I'm a little confused at the question. It would help to have the negative of the profile to mount the paper on. I suppose if one is a little nuts one could make an exact profile with Bondo and wax paper. It'd last a good long time. Ya know think I'll try that. Report
March 3, 20197 yr comment_180808 If ou sand the long grain to 150 sand the end to 400. Be careful not to round off corners or profiles. You can use sand paper backed by fingers or a sponge that is weak enough to be easily depressed into the profile. Also when you finish please consider dye for the first phase it will color uniformly the long and end grains. Edited March 3, 20197 yr by Michael Thuman Spelling Report
