December 13, 20187 yr comment_169549 My son is remodeling his basement and is planning to use Kraft faced fiberglass insulation. Does he need to install a barrier between the insulation and inside of the exterior wall? Danl Report
December 13, 20187 yr comment_169555 I never use FG insulation in a basement... moisture and and mold may become a serious issue later... VOE Put up a closed cell (extruded) polystyrene.. https://www.homeconstructionimprovement.com/basement-wall-insulation-detail/ frame the wall and insulate if you wish.. do it Mooney wall style... MOONEY WALL.pdf Report
December 13, 20187 yr comment_169601 Check out this web site. This solution is better than just polysterene becuase you have to cover that with a thermal barrier of 10 minutes or drywall. This stuff is awesome. https://www.insofast.com/explore/project-prep-before-you-install-insofast.html Report
December 14, 20187 yr Author comment_169759 Thank you all for your advise. I will pass them along. Danl Report
