December 26, 20187 yr Author comment_171351 On 12/24/2018 at 11:11 PM, lew said: I read your post in the “Bugs and Issues” forum. Maybe I misunderstood what you said but you indicated you were hitting Enter to add a picture. To add pictures, you should place the blinking cursor where you want the picture in your text and then click on the image you want to insert. The image needs to be uploaded prior to this process. I agree Lew, and that is what I did. Just then I pressed enter twice so I would a space between the text and the picture. It worked like it should this time. Report
December 26, 20187 yr comment_171362 3 hours ago, hawkeye10 said: I agree Lew, and that is what I did. Just then I pressed enter twice so I would a space between the text and the picture. It worked like it should this time. Not sure why it did that??? Hopefully it will continue to work correctly but if it doesn't, please let us know right away. Looks like you have a nice array of drive centers and a really nice live center for the tail stock. I like those small faceplates. Mines about 6" diameter and that's just a little too big for most work- at least for me. I had the local Vo-Tech School welding kids make me a couple of shot tool rests. Makes working on shorter projects a lot easier. Report
December 26, 20187 yr Author Popular Post comment_171368 2 hours ago, lew said: Not sure why it did that??? Hopefully it will continue to work correctly but if it doesn't, please let us know right away. Looks like you have a nice array of drive centers and a really nice live center for the tail stock. I like those small faceplates. Mines about 6" diameter and that's just a little too big for most work- at least for me. I had the local Vo-Tech School welding kids make me a couple of shot tool rests. Makes working on shorter projects a lot easier. I do have a short tool rest but it needs filing. I would like a banjo that would lock from the front. While I am at it I will show how I mounted the legs for my tray I was building. Here is one of the legs mounted in the lathe. I think it's like you guys suggested. . Here are the legs. They aren't much, but they are a start. This is the completed tray. This is the springboard that holds the legs open and shut. Report
December 26, 20187 yr comment_171373 36 minutes ago, hawkeye10 said: Here are the legs. They aren't much, but they are a start. WOW! If you made them without a duplicator you should be very proud of what you did! It isn't easy to get the same "freehand". Are those dovetails on the angled sides and back? That isn't an easy feat either. First one I did almost drove me nuts!! Report
December 27, 20187 yr comment_171380 9 hours ago, hawkeye10 said: I agree Lew, and that is what I did. Just then I pressed enter twice so I would a space between the text and the picture. It worked like it should this time. I may have found part of the problem you were having. I tried to use one of the images you posted and it wouldn't show up in the post I was creating. The name of the image was "imageproxy.php (1).jpeg" when I downloaded it. I wonder if the name was confusing the software. In effect it has 2 file extensions ".php" and ".jpeg". If you have trouble again, try changing the image to a .jpeg, .jpg or .png and see if that makes a difference. Report
December 27, 20187 yr Author comment_171381 2 hours ago, lew said: WOW! If you made them without a duplicator you should be very proud of what you did! It isn't easy to get the same "freehand". Are those dovetails on the angled sides and back? That isn't an easy feat either. First one I did almost drove me nuts!! No, Lew, they are box joints. Report
December 27, 20187 yr comment_171431 Wow Don, that is beautiful. How about a pic of it folded up? Report
December 27, 20187 yr comment_171454 You do some beautiful work Don. That tray is really cool. You need to post that in the General Woodworking forum too. Report
December 27, 20187 yr comment_171462 22 hours ago, hawkeye10 said: This is the springboard that holds the legs open and shut. That is some seriously mighty fine work Don... I'm impressed... Report
December 28, 20187 yr Author comment_171484 11 hours ago, Cal said: Wow Don, that is beautiful. How about a pic of it folded up? Cal I don't have a picture of it folded up and my daughter has taken the table home. I will try and remember to take a picture the next time I am over there. Report
January 9, 20197 yr comment_173291 The problem was holding a small piece between centers to turn down. I have used another method for MUCH smaller pieces making Christmas tree ornaments.. I find true centers on both ends, using the lathe. I then drill a hole with the lathe ( size dependent on dia of work piece) and glue in a hardwood dowel. Now I have a safe, sturdy and centred piece to turn. If the dowell is quarter in dia or less, caution must be used by taking light cuts. After turning I cut off the dowel. Report
