Popular Post Dadio Posted November 30, 2018 Popular Post Report Posted November 30, 2018 I had a ZC plate for my Bosch 4100 benchtop saw, but didn't want to mess up the factory plate wit a 45 degree setting so I ordered a pack of ZC tape from Fast Cap. Took longer to open the plastic package than to install. I made a couple of cuts, and it performed well. There are 5 strips in a pack and that will be more than enough for my needs. Herb Stick486, John Morris, Grandpadave52 and 2 others 4 1 Quote
Grandpadave52 Posted December 1, 2018 Report Posted December 1, 2018 Thanks Herb for the update. Those appear much thinner than I expected which is a good thing. I assume the thickness is minimal so it will be a non-issue for slightly tilting/rocking the material?? Gene Howe and Cal 1 1 Quote
Stick486 Posted December 1, 2018 Report Posted December 1, 2018 good to know.. Thanks Herb.. Dadio 1 Quote
lew Posted December 1, 2018 Report Posted December 1, 2018 I've use pink duct tape on a jig for rolling pins. I don't think it works as well as what this product would but it sure makes it easier to see layout lines. Grandpadave52, Dadio and Cal 2 1 Quote
Dadio Posted December 1, 2018 Author Report Posted December 1, 2018 (edited) 4 hours ago, Grandpadave52 said: Thanks Herb for the update. Those appear much thinner than I expected which is a good thing. I assume the thickness is minimal so it will be a non-issue for slightly tilting/rocking the material?? I mic it as .53mm, not sure what that works out in inches, I will let you math guys figure that out.. Herb Edited December 1, 2018 by Dadio Grandpadave52 1 Quote
HandyDan Posted December 1, 2018 Report Posted December 1, 2018 Thanks for the report and pictures. I like what I see. Quote
Stick486 Posted December 1, 2018 Report Posted December 1, 2018 1 hour ago, HandyDan said: Thanks for the report and pictures. I like what I see. me too... Quote
Stick486 Posted December 1, 2018 Report Posted December 1, 2018 (edited) 3 hours ago, Dadio said: I mic it as .53mm, not sure what that works out in inches, I will let you math guys figure that out.. Herb it's 1/64''... and I'm not the mathy type... Edited December 1, 2018 by Stick486 Cal, Dadio, Grandpadave52 and 1 other 4 Quote
Popular Post Dadio Posted December 1, 2018 Author Popular Post Report Posted December 1, 2018 The concern about it tilting on the tape causing a slight error in angle cut, I did a test this morning and I cut a couple of inches off an 8 " long scrap. It seemed to give a tight miter joint, A longer piece shouldn't be a problem. If a rip miter was cut, it might be a problem if the material is wider than 2" but then another piece of tape added to the right of saw blade should correct that. Herb HandyDan, HARO50, Cal and 2 others 4 1 Quote
Michael Thuman Posted December 3, 2018 Report Posted December 3, 2018 Maybe, Cut the tape to the length of the insert. Then with an indicator level the tape to the table. HARO50 1 Quote
Gene Howe Posted December 4, 2018 Report Posted December 4, 2018 @Dadio, you convinced me. Thanks. Because I make my on inserts and, because I like to play, I might make an insert with a dado to fit the tape. HARO50, Dadio and Cal 3 Quote
Stick486 Posted December 4, 2018 Report Posted December 4, 2018 1 minute ago, Gene Howe said: I might make an insert with a dado to fit the tape. logical... Quote
Popular Post Gene Howe Posted December 4, 2018 Popular Post Report Posted December 4, 2018 1 minute ago, Stick486 said: logical... Now, there's a term not often associated with my activities. Thanks. Stick486, Dadio, Gerald and 4 others 7 Quote
Popular Post Stick486 Posted December 4, 2018 Popular Post Report Posted December 4, 2018 Just now, Gene Howe said: Now, there's a term not often associated with my activities. Thanks. so now we change logical to confused??? HARO50, Dadio, Gene Howe and 3 others 6 Quote
Dadio Posted December 4, 2018 Author Report Posted December 4, 2018 (edited) 39 minutes ago, Gene Howe said: @Dadio, you convinced me. Thanks. Because I make my on inserts and, because I like to play, I might make an insert with a dado to fit the tape. You have to note that on the TS the point of the miter is laying flat on the table, and on the miter saw it is on edge. So the 1/64 effects the vertical cut on the miter saw,and that may be different than what I show. In that case other pieces of tape might be required on the miter saw table on both aides of the blade. That is a good idea of making a dado to replace the strips. Just saying, Herb Edited December 4, 2018 by Dadio Cal and DuckSoup 2 Quote
Gene Howe Posted December 4, 2018 Report Posted December 4, 2018 There's no problem with the tape on my Bosch Miter Saw">SCMS as the insert sets ever so slightly lower in the miter arm and table assy. So the tape on the factory insert actually is about the same height as the surrounding metal. For the ZCI in the TS, a recess in it for the tape would solve two (imaginary?) problems. First, there would be no worries about differing levels causing a bad fitting joint and second, no worries about catching the tape on the leading edge/end of a board being ripped. Since I make my ZCIs to accept a replaceable strip, planing it to accept the tape would be no problem. The tape would be much easier to replace than that strip of wood. HARO50, Cal and Dadio 3 Quote
HARO50 Posted December 8, 2018 Report Posted December 8, 2018 Sounds logical! John Dadio and Cal 2 Quote
Dadio Posted December 9, 2018 Author Report Posted December 9, 2018 When I had my old Craftman TS, I made a ZCI that had a 1 1/2" wide recess with a sliding dovetail edges where the blade cut through. Then made up a handful of inserts to slide in and out as needed. It required some work to make , but it lasted a long time. Herb HARO50, Cal, DuckSoup and 1 other 4 Quote
