October 7, 20188 yr Popular Post comment_161959 I have finished the box made from a damaged birch tree on my sons' property. He loved his birches. The box is a gift to my daughter-in-law. finished with 2 coats of brushed on varnish and 1 wipe on coat. The bark was finished using water based urethane. Edited October 7, 20188 yr by It Was Al B Report
October 7, 20188 yr comment_161961 Beautiful Al...just magnificent. I love the contrast and symmetry between the live edge and finished pieces. The grain is so rich and full of character. I'm sure you did, but just in case, you did sign and date it on the bottom I assume? A great and lasting tribute to Michael! Report
October 7, 20188 yr comment_161967 Beautiful box. Great design. Excellent workmanship. As has been said, leaving the bark was brilliant. Report
October 7, 20188 yr Author comment_161976 Thanks all. I did sign and date it on the bottom Dave. Report
October 9, 20188 yr comment_162085 Great work Al. I wish we had Birch here in Tenn. What did you do about the moisture content? Report
October 9, 20188 yr Author Popular Post comment_162099 The tree was cut into short lengths, under 2' long. I ripped the short logs on my bandsaw into 2" + thick strips. I ran those pieces thru my little thickness planer for uniform thickness. After about 6 months drying, some warping and checking had occured, but not bad. I ran them thru the planer again and it was about a month before I eventually started the box. Then cut the blocks into the pieces needed using my bandsaw and tablesaw. A final run thru the thickness planer to get the desired thicknesses for the box. The only drying was about 7-8 months of storage in my shop. I believe the short lengths helped speed up the drying. The pieces were stickered to allow air on all sides. Report
