June 13, 20188 yr comment_151563 You should be able to route a 2" radius with a bearing bit . If I did it I would cut it out of a wide board and leave plenty on each side to hang on to and then cut it to fit after I routed it., Just a suggestion. Herb Edited June 13, 20188 yr by Dadio Report
June 13, 20188 yr Author comment_151578 1 hour ago, Dadio said: You should be able to route a 2" radius with a bearing bit . If I did it I would cut it out of a wide board and leave plenty on each side to hang on to and then cut it to fit after I routed it., Just a suggestion. Herb 1 hour ago, Dadio said: You should be able to route a 2" radius with a bearing bit . If I did it I would cut it out of a wide board and leave plenty on each side to hang on to and then cut it to fit after I routed it., Just a suggestion. Herb I have the templates for cutting the radii. The no-drip edge bit will be used to cut the no-drip edge on the straight and corner (radiused) edging pieces. These no-drip edge bits aren't too common. I bought mine from CMT. I placed the order by phone and the rep told me that they had only sold 10 of them the previous year. The bit is most commonly used to add a no drip edge to solid surface counter tops. Report
June 14, 20188 yr comment_151595 5 hours ago, JIMMIEM said: I have the templates for cutting the radii. The no-drip edge bit will be used to cut the no-drip edge on the straight and corner (radiused) edging pieces. These no-drip edge bits aren't too common. I bought mine from CMT. I placed the order by phone and the rep told me that they had only sold 10 of them the previous year. The bit is most commonly used to add a no drip edge to solid surface counter tops. Is this it? https://www.amazon.com/CMT-880-531-11-Surface-No-Drip-Diameter/dp/B0023NVSFS Herb Report
June 14, 20188 yr Author comment_151613 8 hours ago, Dadio said: Is this it? https://www.amazon.com/CMT-880-531-11-Surface-No-Drip-Diameter/dp/B0023NVSFS Herb This is the one. The one that has a bearing will not work on a curved piece. The counter corners will be curved.....2 inch radius. https://www.amazon.com/CMT-881-501-11-Surface-No-Drip-Diameter/dp/B0023NUM8M Report
June 14, 20188 yr Author comment_151614 13 hours ago, DAB said: pic of bit? how big is the diameter of the bit? https://www.amazon.com/CMT-881-501-11-Surface-No-Drip-Diameter/dp/B0023NUM8M Report
