June 7, 20188 yr Popular Post comment_151040 Ok, awhile back I picked a plastic tub of tools and such....in one of the many "layers" of toys in that tub, was a chisel shaped object. All metal, mushroomed tip, must have been hurting, tip is all red... Well, finally some free time in the shop, got rid of that mushroom.. Could even read all the writing on it..."Made by Crescent Tool Co." "Jamestown, N.Y." No. 175 1 1/4 Made in USA Hmmm, that might take awhile....bevel had a 40+degree angle to it, and was skewed.... Took a large cup of water to the shop, and set it right beside the grinder. VE Haft Werk to do..... Looking better, now. No attempt at a bevel..just straight in. And dunk it often. Once this was straight, I could work on a new bevel...at 35degrees.. And made sure the back was flat.. Will do....then the stones and papers.. A very coarse stone, until a wire edge showed up.. Bench dog to keep things from sliding away. Medium stone..600 grit..then the fine stuff Set each paper, 1000 grit, 1500 grit, and 2000 grit right on the stone. Sprtiz of WD40 on the stone, and the paper...then the leather belt strop, loaded up with the green compound... First test drive.. Yep, it will curl some shavings...but, this is not what this chisel was designed for...next test drive.. Say this is a floor, or ceiling joist, and you needed to run a water line, or electric lines through it...rather than drill a hole that may or may not fit..just chop your way through.....including through lath with brown coat, joists with nails..this chisel will cut through....and that be the hammer most often used... These were sold with a shiny blade, a blue/black handle, and a red top.. Just like new. Might have to find a use for this one, around the house... Report
June 7, 20188 yr comment_151058 Excellent! Yet another great rescue from a scrap iron heap. Well done. Report
