March 12, 20188 yr comment_143163 I've used hide glue before to make some small boxes with no stress on the joints when finished. This project there may be some stress on them and I don't want them coming apart. The reason I used it before is the long open time so I can get all the sides and joints adjusted. Is this a good choice or should I use the normal Titebond? Report
March 12, 20188 yr comment_143165 Titebond III has a little longer open time. I think Titebond also makes an extend time glue but not certain about that. Report
March 12, 20188 yr comment_143167 9 minutes ago, lew said: Titebond III has a little longer open time. I think Titebond also makes an extend time glue but not certain about that. I saw Titebond II extended at Woodcraft the other day Report
March 12, 20188 yr comment_143168 I agree with Lew. I use TB III for all my boxes and never have a problem with open time. However, I recommend that you do a dry fit, including setting clamps, before applying glue. Make any necessary corrections, then glue and clamp. I made a glue-up jig that holds 2 sides at 90 degrees while the other 2 sides mate up. Makers the whole process much easier to control. Report
March 12, 20188 yr Author comment_143170 I've done a couple of dry fits and everything looks ok. I have a couple of 90 degree clamps I'll dig out to help me along and I do have a fresh bottle of TBIII I'll use. Like all have said before, I'll post pictures when it's done. Thanks for the in-put. Report
March 12, 20188 yr comment_143171 I use Titebond II extened for everything, never had a failure, and if you break a joint it takes wood with it. I use Titebond II panel glue for veneering,(the brown colored). it has good open time. Herb Edited March 12, 20188 yr by Dadio Report
March 12, 20188 yr comment_143178 I use Elmer's, I'm partial to the cow. Been using it for many years. Report
March 12, 20188 yr comment_143185 19 minutes ago, Smallpatch said: I use Elmer's, I'm partial to the cow. Been using it for many years. Good ole Borden's Elmers, that was the standard glue for commercial carper work for many,many years, until they were bumped by Franklins TB. Herb Report
March 12, 20188 yr comment_143195 1 hour ago, Smallpatch said: I use Elmer's, I'm partial to the cow. Been using it for many years. 1 hour ago, Dadio said: Good ole Borden's Elmers, that was the standard glue for commercial carper work for many,many years, until they were bumped by Franklins TB. Herb Ever ponder if the milk & the glue came out of the same vat? ---- Report
March 12, 20188 yr comment_143198 I find titebond 111 works well when making glue-ups on bandsaw boxes. I have used regular titebond 11 but found that I really have to move to complete the glue-up. Report
March 12, 20188 yr comment_143207 look to Weldbond... longer open time and stronger than strong... https://www.speedyproducts.com/pages/weldbond-specs-instructions Edited March 12, 20188 yr by Stick486 Report
March 13, 20188 yr Popular Post comment_143221 4 hours ago, Grandpadave52 said: Ever ponder if the milk & the glue came out of the same vat? I suspect Elsie went into the glue vat when she stopped giving milk. Well, that or with a box of hamburger helper. Report
March 13, 20188 yr Popular Post comment_143223 1 minute ago, p_toad said: I suspect Elsie went into the glue vat when she stopped giving milk. Ah, makes perfect sense now...that's when it became "Elmer's" glue! Report
March 13, 20188 yr comment_143319 1 hour ago, Cliff said: I've used hide but it is a PITA I can still remember my dad using hide glue and always having to warm it up before use; and it stunk!. (or, to borrow a phrase from The Critic - IT STINKS!") Report
