Popular Post Dadio Posted February 6, 2018 Popular Post Report Posted February 6, 2018 (edited) This is how I set up the Dust Collection on my RA Saw. It plunges in and out of a wooden box and has a zero clearance insert in the table that has a dado under it back to the box so the saw dust below the blade is sucked out. No sawdust at all comes out of the blade guard fitting. Herb Edited February 6, 2018 by Dadio Grandpadave52, HARO50, Stick486 and 2 others 5 Quote
Fred W. Hargis Jr Posted February 6, 2018 Report Posted February 6, 2018 I do like that, I'm guessing you keep your saw at 90º? HARO50 1 Quote
Dadio Posted February 6, 2018 Author Report Posted February 6, 2018 (edited) 30 minutes ago, Fred W. Hargis Jr said: I do like that, I'm guessing you keep your saw at 90º? Yeah I do, Fred, I use it exclusively for 90 deg. cut offs. I hate to cut off long boards on the table saw. I do the miter cuts on the TS. Not doing any long material miter cuts any more, if I cut long stuff, like rafters etc. I do it out side on saw horses and a chop saw or skill saw. Also I might add I cut wedges and lay them on the table sometimes to make the angle either up and down, or flat,thus keeping the blade at 90 deg. to the fence. Herb Edited February 6, 2018 by Dadio HARO50 1 Quote
Grandpadave52 Posted February 6, 2018 Report Posted February 6, 2018 That is an awesome design Herb. I really like it/ My RA needs a new top anyway so you've inspired me. It'll be a while but I will give my best effort to come half way close to this. It appears the insert is replaceable/removable/changeable as needed. Very cool! THANKS for sharing! Quote
HARO50 Posted February 6, 2018 Report Posted February 6, 2018 A lot of thought and planning went into that! Great design, Herb. John Quote
Wil Posted February 6, 2018 Report Posted February 6, 2018 Herb, this is great. I have the same saw and use for crosscuts only as well. What did you do under the saw? Im assuming just enclosed the metal support frame? Quote
Dadio Posted February 7, 2018 Author Report Posted February 7, 2018 1 hour ago, Wil said: Herb, this is great. I have the same saw and use for crosscuts only as well. What did you do under the saw? Im assuming just enclosed the metal support frame? Wil, the Metal channel saw frame sets on a 3/4" plywood top which is lower than the long off feed top of the bench,(Was Made for a Chop Saw Originally). On top of the metal saw channel is another piece of 3/4" ply to bring it up to height. Then the final layer is a removable top so it can be replaced if it gets beat up. In the 2nd picture you can see the replaceable top and the sub top. I made a couple of extra inserts when I made the one shown, just in case I later want to replace it. The hole in the insert is a finger hole to pull it out , the reason I used a T/G is I didn't want any metal fasteners in proximity of the blade. As I said before ,this set-up seems to capture 90+% of the sawdust. I added a couple of holes in the side of the box to add make-up air since I have plenty of air flow and it keeps the airflow in the main duct up without choking it down. Herb Grandpadave52, HARO50 and Wil 3 Quote
oldwoodie Posted February 7, 2018 Report Posted February 7, 2018 I got a new table and blade guard for a Craftsman RA saw through their recall at no cost. Grandpadave52 and Dadio 2 Quote
Kevin Beitz Posted October 22, 2019 Report Posted October 22, 2019 I do the same thing. I also made a 45 degree adapter to cut angles. It holds the board at the angle instead of moving the saw head. Quote
