January 2, 20188 yr comment_135876 Started roughing a Beads of Courage Bowl and noticed that this blank may allow for a natural edge or bark on side , just an area about 2 inch wide by 3 to 4 long. Question is has anyone had good luck doing a bark side on a hollow form? Report
January 2, 20188 yr comment_135881 I haven't but here's a site from someone who seems to have mastered it- http://www.mikesorge.com/natural-edge.html Report
January 2, 20188 yr Author comment_135959 Very interesting Lew. If I can get it to stay on it will not be that much. Report
January 2, 20188 yr comment_135981 2 hours ago, Gerald said: Very interesting Lew. If I can get it to stay on it will not be that much. Pictures...gotta' see some pictures...please & thank-you Report
January 3, 20188 yr Author comment_136014 This is the outside. Now to hollow. By the way this is Bradford Pear Report
January 3, 20188 yr comment_136016 I think I'd give it a good saturation of thin CA. Might help keep things in place. Are you going to add a dutchman across the crack at the base? Edited January 3, 20188 yr by lew Report
January 3, 20188 yr Author comment_136027 Lew I used CA on the edges. That crack seems stable so I used CA to fill it . Funny thing is I drilled it after the photo and went thru the bottom. I think I have saved it with a plug I turned to fill the bottom, will see tomorrow. Report
January 3, 20188 yr comment_136032 You're going after it the right way. Slow but sure. Looks good so far. I will keep my fingers crossed for you. Report
January 3, 20188 yr comment_136074 16 hours ago, Gerald said: This is the outside. Now to hollow. By the way this is Bradford Pear Thanks for the pictures Gerald...One of the weaknesses of a Bradford Pear is internal occlusions. That said, I had no idea BP could have such a grain pattern... Hope this one holds together for you. Can't wait to see it all finished. Report
January 3, 20188 yr Author comment_136088 1 hour ago, Grandpadave52 said: Thanks for the pictures Gerald...One of the weaknesses of a Bradford Pear is internal occlusions. That said, I had no idea BP could have such a grain pattern... Hope this one holds together for you. Can't wait to see it all finished. As a matter of fact I have discovered since I started turning BP a great deal of it has a curl in it , probably due to the stress. The pieces from this tree has a beautiful red color in the heart which a lot of it has when fresh cut. The exception here is that the last piece I finished in this tree held the red as seen below. Report
