November 30, 20178 yr Popular Post comment_132813 Pretty cool and quick way to make a simple drawer https://www.wwgoa.com/video/posthaste-projects-instant-drawer-008593/?utm_source=facebook&utm_medium=organic&utm_campaign=A5439&vsoid=A5439 Report
November 30, 20178 yr comment_132819 Quick and simple, one set-up, and good to go...as long as your stock is milled to exactly 1/2". The only other downside, which isn't, is that when you cut the groove for the bottom you end up with a square through hole at the joints. Not something I would want for a piece of furniture. However, that fix is simple...just glue in a plug. Anyway, great video, thanks Keith. Report
November 30, 20178 yr comment_132827 2 hours ago, schnewj said: Quick and simple, one set-up, and good to go...as long as your stock is milled to exactly 1/2". The only other downside, which isn't, is that when you cut the groove for the bottom you end up with a square through hole at the joints. Not something I would want for a piece of furniture. However, that fix is simple...just glue in a plug. Anyway, great video, thanks Keith. Or, attach a false front. Edited November 30, 20178 yr by Gene Howe Report
November 30, 20178 yr comment_132829 18 minutes ago, Gene Howe said: Or, attach a false front. One of the other ways to "skin a cat"! I love woodworking! Report
November 30, 20178 yr comment_132836 2 hours ago, schnewj said: One of the other ways to "skin a cat"! I love woodworking! You been drinking your coffee black again? John Report
November 30, 20178 yr comment_132842 1 hour ago, HARO50 said: You been drinking your coffee black again? John he didn't say kill it... he said skin it... Report
November 30, 20178 yr comment_132843 1 hour ago, HARO50 said: You been drinking your coffee black again? John ABSOLUTELY! Is there any other way? Report
November 30, 20178 yr comment_132845 1 minute ago, Stick486 said: he didn't say kill it... he said skin it... There are a 101 uses for a (already) dead cat. Amazon: $8.98 Report
November 30, 20178 yr comment_132853 skin the cat.. and then let it grow a new skin... skin it again... and again................................. no need to kill it... Report
November 30, 20178 yr comment_132856 My dad was a cat skinner for a while. In the Sea Bees. Later, in the oil patch. Wonder if they still use that term for bulldozer operators? Report
December 1, 20178 yr comment_132860 That is even easier than using a 1/4" straight bit to do the same joint. For the bottom, I dry fit the drawer, use a band clamp to hold it together, then use a slotting bit to cut the groove for the drawer bottom. All I have to do is round the corners of the bottom to match the diameter of my slotting bit. Works wonderfully. Lee Valley makes 2 different slotting bits just for this purpose, 1 for 1/8" thick bottoms, the other for 1/4" bottoms. Report
