November 4, 20179 yr comment_130163 Is there anything that will take minwax wood stain off of vinyl siding? Larry Edited November 19, 20179 yr by Ron Dudelston Added tags Report
November 4, 20179 yr comment_130169 Maybe that citrus type paint remover. JUST GUESSING! Try it in an inconspicuous place to make sure it doesn't damage the siding. Maybe a toothbrush to help, depending on the area?? Report
November 4, 20179 yr comment_130170 1 hour ago, Larry Cutlip said: is there anything that will take minwax wood stain off of vinyl siding? sure at the expense of the siding... try orange hand leaner and or hand cream... paint thinner is about the safest solvent... clean that up w/ orange hand leaner and or hand cream... plan on a lightened spot on the siding... see the PDF on solvents for the risky plan ''B''.. Solvents for Cleaning....pdf Solvents And Thinners.pdf Report
November 5, 20179 yr comment_130209 How long has it been on there? Did you try pressure washing it? Report
November 5, 20179 yr comment_130217 24 minutes ago, p_toad said: Did you try pressure washing it? that injects water behind the siding which could beget mold... Report
November 5, 20179 yr comment_130249 The bad news is that I never, ever, found a way to get Minwax stain off of vinyl siding (don't ask how I know about this). I finally gave up and just replaced the section with a piece of spare vinyl I had left over. Report
November 5, 20179 yr comment_130259 The auto parts stores carry plastic cleaners/polishers for automotive headlights and trim and may be worth a try. Report
November 6, 20179 yr comment_130341 9 hours ago, Larry Cutlip said: Been on about 6 months. change the siding... Report
November 7, 20179 yr comment_130499 you could also try some cutting compound and a buffer on the end of your drill. Report
