October 25, 20179 yr comment_129067 I have a question about scroll saw blade nomenclature. I am doing a project that requires some scroll saw blade work, and the plans specify a #2 reverse tooth scroll saw blade. I understand the reverse tooth, but what does the #2 signify? I was looking at a scroll saw blade selection chart on the Olson blade web site, and every specification that I could imagine was listed on the chart, along with a Universal Number column. Any ideas? Edited November 22, 20179 yr by Ron Dudelston tags added Report
October 25, 20179 yr comment_129071 This may help- http://scrollsawreviews.com/accessories/blades/scroll-saw-blade-selection-guide Report
October 25, 20179 yr comment_129073 I could help if I knew what you will be cutting. Hard wood or soft, and how thick is the wood to be cut.? Also does your saw take pinless blades? Report
October 25, 20179 yr Author comment_129075 27 minutes ago, Smallpatch said: I could help if I knew what you will be cutting. Hard wood or soft, and how thick is the wood to be cut.? Also does your saw take pinless blades? I will be cutting walnut veneer spray-adhered to a 3/16" piece of walnut. My saw takes pinless blades. Report
October 25, 20179 yr Author comment_129076 1 hour ago, HandyDan said: I would pose that question in the scroll saw section too Thanks Dan. I forgot we have a scroll saw section. I posted this before I looked at Lew's response. His link actually gave me the answer I was looking for. But, thanks again for the reminder on the scroll saw section. Edited October 25, 20179 yr by PostalTom Updated my answer. Report
October 26, 20179 yr comment_129094 Since Lew got you what you needed I will suggest if you don't have a lot of learning on the scroll saw I would suggest the blades not have reverse teeth for it will want to kick the wood up as you are cutting. Report
October 26, 20179 yr Author comment_129132 9 hours ago, Smallpatch said: I would suggest the blades not have reverse teeth for it will want to kick the wood up as you are cutting. That makes a lot of sense. I haven't done any scroll sawing in years, and very little then. I'll go that route. Thanks. Report
