July 1, 20179 yr comment_115041 @kmealy from some place else that someone is looking for some help... I'd like to know the answer too... their statement... Okay so I used the Minwax oil based poly on my hard wood floors. It has been just over a month and they still aren't cured. Two of my rooms are cured but not my main room and hallway. I used the same cans and stirred them constantly as I was applying it. I can literally scratch them with my fingernail and I dropped something on them the other day and it scratched it terribly. I let the stain dry for a week before I put the polyurethane on. I waited 24-48 hours between each coat of poly and I made sure I coated them on days that were not humid. What do I do? I have no clue what I did wrong Report
July 1, 20179 yr comment_115046 The cans of poly might have been the same but how old they were and under what conditions they were stored might be the problem. Since they say that this is in just one of several rooms then I would say the product used in that room was old and/or stored improperly. It might be old because the store might not have rotated their stock correctly, if new replacement product was put out first instead of old product replacing sold product and new product replacing stored product then it could have been sitting there in the can and get past the usable date. They might have bought a large enough quantity that they got old product from storage. Storage environment might also have to do with quality of product. If it was stored against an out side wall or in a unregulated warehouse and was subjected to cold or heat or both then it might still be in date for use but might have been damaged by the environment in which it was stored. One more thought is the flooring they used it on. Did this room have the same flooring or was it a different flooring product that might be the problem. Is it leaching chemicals into the finish and keeping it from drying? I know some of the import flooring has been band from import after it was found to contain excessive amounts of formaldehyde. Is it possible that this flooring is some that was imported before the ban? Report
July 1, 20179 yr comment_115059 There are a number of possible causes - Finish is no good (as described above) - Wood is different - might have something in it or just a wood that emits fumes that prevent finish from curing, cedar and teak are two examples - Applied too thickly (does not allow oxygen to get to lower layers) - Too cold (unlikely since probably adjacent rooms) - Improperly prepared surface (did not say what he/she did to prep, was there an existing finish?) Stain applied too thickly (not wiped off) or incompatible.chemical Report
July 1, 20179 yr comment_115076 I just ran across the same predicament. I applied shellac first as a sealer and then the poly. The shellac was not dewaxed and I believe that was the problem. Applied a couple coats of sanding sealer and problem solved. If there was wax on the floor the same problem would arise. Report
July 1, 20179 yr comment_115101 So, Keith & Dan, what is the fix for Stick's friend? I imagine a room with a sticky floor. Do you strip it with a chemical stripper or let it cure out another month, or what? Cal Report
July 1, 20179 yr comment_115115 I would give it a few days. It may settle in and dry but probably not to the hardness it would have been. Removing the finish and starting over is the best way to go. Report
July 3, 20179 yr Author comment_115256 On 7/1/2017 at 5:19 AM, clhyer said: So, Keith & Dan, what is the fix for Stick's friend? I imagine a room with a sticky floor. Do you strip it with a chemical stripper or let it cure out another month, or what? Cal @kmealy do you have a solution??? Report
July 3, 20179 yr comment_115274 I would think the bad stuff is going to have to come off. I am not sure a stripper is the way to go or not. Outside my scope of experience. Report
July 3, 20179 yr comment_115276 Was the stain oil based .I've always heard, " you can put water base over oil base but do not put oil base over water base. Report
