April 18, 20179 yr Author comment_106706 This is what I found: I moved the refrigerator into the middle of the kitchen. It does not have an ice maker, but the flour I spread around it told the tale. I took a flashlight and shined it down into the pan in the rear, and there was water standing in it. I have moved the refrig. to the other end of the room and will replace the refrig. while the floor dries out a little before replacing the floor. Thanks for all the suggestions! Report
April 18, 20179 yr comment_106714 1 hour ago, oldwoodie said: This is what I found: I moved the refrigerator into the middle of the kitchen. It does not have an ice maker, but the flour I spread around it told the tale. I took a flashlight and shined it down into the pan in the rear, and there was water standing in it. I have moved the refrig. to the other end of the room and will replace the refrig. while the floor dries out a little before replacing the floor. Thanks for all the suggestions! There should be water in that pan. It comes from the defrost cycle and is supposed to evaporate. Some refrigerators have a fan that is supposed to assist in the evaporation process. Maybe the problem is an easy fix. Report
April 18, 20179 yr comment_106715 1 hour ago, oldwoodie said: I took a flashlight and shined it down into the pan in the rear, and there was water standing in it. the pan shoud have either an evaporator fan or heater coil to evaporate the water... cheap DIY fix... check w/ eparts... Report
April 18, 20179 yr comment_106717 2 minutes ago, lew said: There should be water in that pan. It comes from the defrost cycle and is supposed to evaporate. Some refrigerators have a fan that is supposed to assist in the evaporation process. Maybe the problem is an easy fix. Look to see if the pan is sitting level and not broken. Bad door gaskets can cause excessive frost build up which leads to excessive water in the pan but being in several day cycles could the frdige see a lot of use for the day before the water on the floor ? Roly Report
April 19, 20179 yr comment_106753 16 hours ago, oldwoodie said: This is what I found: I moved the refrigerator into the middle of the kitchen. It does not have an ice maker, but the flour I spread around it told the tale. I took a flashlight and shined it down into the pan in the rear, and there was water standing in it. I have moved the refrig. to the other end of the room and will replace the refrig. while the floor dries out a little before replacing the floor. Thanks for all the suggestions! So it was the fridge! Awesome job guys, this was a great exercise in collaborative sleuthing! Report
April 19, 20179 yr Author comment_106796 Local repairman said he would charge $58.00 for a service call, he would charge $25.00 plus parts and labor if I bring it to him. The way I figure it is that if I take it to him and it is not repairable, then I have lost less money than if that is the scenario if makes a home service call. So, I think I will deliver it to his shop, pay the cost to have it looked at. I know that I am a cheapo when it comes to spending someone else's money, as well as to spending my own! So, you don't have to tell me! Thanks again for all your input! I will follow up on this after the dust settles. Report
April 27, 20179 yr Author comment_107533 A gift of another refrigerator took care of the water problem. Now I have to replace the floor tile. Thanks again for your help! Report
