February 5, 20179 yr comment_96172 I have converted my drill press to variable speed using a 3-phace motor and a VFD. I have a digital speed readout using a Hall Effect sensor and a magnet on the quill shaft pulley. Right now, I have a speed range of ~60 to 2650 RPMs. Will this be adequate for most woodworking tasks? I still have a couple of changes using the step-pulleys but I haven't measured the speeds available. Edited November 24, 20178 yr by Ron Dudelston tags added Report
February 5, 20179 yr comment_96177 That sounds pretty good. If you small diameter twist bits, you could probably go up to around 3000 to 3200 rpm Report
February 5, 20179 yr comment_96180 Here is a posted speed chart from Wood. Mag. speedchart.pdf Report
February 6, 20179 yr comment_96303 I did the same with a treadmill motor and speed control. Except for small diameter drill bits which run at high speed I find that most tasks require only speeds of about 100 rpm. One has to spend high dollar for those drill presses that have a lowest speed of 140 or so. Report
