December 17, 20169 yr comment_88224 Maybe put one on each end for left cut,right cut ,unless you found a raker tooth. Report
December 17, 20169 yr comment_88227 Now that's pretty cool! I just recently got a Harbor Freight angle grinder and I have a couple of old saw blades-I'm set!!! Report
December 17, 20169 yr Author comment_88240 I had an old harbor freight 10" and quickly cut our a prototype. It worked really well. I would not use it as it is. I would make it properly. I would make it longer and a nicer handle. Don't think angle would do any harm. I did not have any problem with bending Report
December 17, 20169 yr comment_88245 2 minutes ago, Ron Altier said: What do you consider as thin? I have a old sacrificial blade that is either 1/16" or 3/32". It has some teeth missing. I wonder if it will have too much flex. Report
December 17, 20169 yr Author comment_88246 This one is one 16ths blade and one eight tooth and has no bendage. However the length is only about 3" Report
