November 25, 201610 yr comment_85362 20 minutes ago, HandyDan said: You don't want to resaw a half sheet of plywood? Report
November 25, 201610 yr comment_85365 47 minutes ago, HandyDan said: You don't want to resaw a half sheet of plywood? or log you can't pick up... Report
November 25, 201610 yr comment_85377 Well...one could buy that saw, and sell 3 of those risers blocks for about $50 each...... I don't know, might be too big to stuff into my van.... Report
November 25, 201610 yr comment_85380 that is the same saw I have only in the ridgid brand and have 1 riser block ,it will saw 11" hi.But I had to increase the motor size to get that because the motor will not pull that much of a cut. I can see why he is selling .probably went to a larger saw. Herb Report
November 26, 201610 yr comment_85386 Might lay it on it's side and make a mill out of it with a 5HP gas engine. Report
November 26, 201610 yr comment_85387 Maybe hook it up to the power take off on the 4X4 and straddle the log, start it up and back up in reverse. Herb Report
November 26, 201610 yr comment_85486 Use the tractor and the flat belt like the old timers used to do. Herb Report
November 28, 201610 yr comment_85654 Ya know - - - it dawned on me that this thing might have a perfectly valid use Sawing up Styrofoam sheets to insulate tractor trailers. Report
November 28, 201610 yr comment_85715 @Fred W. Hargis, Jr...still shows available...think I read somewhere else you just bought some new step work-platforms...would look good in your new shop plus you've now got the means to reach the tension lever... Probably should invest in a fall prevention harness though... Report
November 28, 201610 yr comment_85724 9 hours ago, Cliff said: Ya know - - - it dawned on me that this thing might have a perfectly valid use Sawing up Styrofoam sheets to insulate tractor trailers. I don't think you would like that, the shop and you would be covered with syrofoam dust in short order. They make hot wire cutters for that chore. Report
November 28, 201610 yr comment_85725 6 minutes ago, Dadio said: I don't think you would like that, the shop and you would be covered with syrofoam dust in short order. They make hot wire cutters for that chore. take a dull blade and sharpen it into a knife blade... Report
November 29, 201610 yr comment_85728 43 minutes ago, Stick486 said: take a dull blade and sharpen it into a knife blade... Might be able to buy a knife blade, take awhile to sharpen all the teeth back to a knife blade. I had another thought, buy the saw remove 3 riser blocks and sell them for $50. each, they will fit a number of brands of saws. and get a 108" blade and you are ready to go. I don't think a person could get enough tension on the blade the way it is, besides not having enough power to cut with it. Who ever did that wasn't thinking quite right. Herb An after thought, maybe this guy was a boat builder and was sawing balsa or foam blocks for infill for fiber glass.Hmmmmmmm Edited November 29, 201610 yr by Dadio Report
November 29, 201610 yr comment_85737 2 hours ago, Dadio said: Might be able to buy a knife blade, take awhile to sharpen all the teeth back to a knife blade. you can buy one ready to go... bust the set and sharpen the trailing edge...... Report
November 29, 201610 yr Author comment_85758 The idea about selling the extra riser blocks came up a few times, and it's a good one. There are a number of times someone bought one of those older Delta/Rockwell saws and want a riser. If they have all the other parts (the guard extension, etc.) they may well be worth more than the saw. Report
November 29, 201610 yr comment_85794 2 hours ago, Fred W. Hargis, Jr said: The idea about selling the extra riser blocks came up a few times, and it's a good one. There are a number of times someone bought one of those older Delta/Rockwell saws and want a riser. If they have all the other parts (the guard extension, etc.) they may well be worth more than the saw. Fred those are pretty standard,I have a Ridgid,but the same as the Jet,Grizley ,Delta, I think even the HF is the same, the castings are all made in the same mold. You are right about the guide bar/blade guard is longer Herb Report
November 29, 201610 yr comment_85799 25 minutes ago, Dadio said: Fred those are pretty standard,I have a Ridgid,but the same as the Jet,Grizley ,Delta, I think even the HF is the same, the castings are all made in the same mold. You are right about the guide bar/blade guard is longer Herb I think Delta has two or three different styles of guide bars. Report
