November 1, 201610 yr comment_82073 On 10/31/2016 at 0:00 AM, HandyDan said: I don't like to clean up. Happens when I can't find something. Your coffee can is upside-down! John Report
November 1, 201610 yr comment_82086 23 minutes ago, HARO50 said: Your coffee can is upside-down! John I didn't want the air to get out. Report
November 1, 201610 yr comment_82100 EOD? Explosive, Ordinance, Disposal? I seem to think the Dungeon Shop would qualify as the messiest shop around......but, there are some days.. That this happens Hey...shavings happen.... Edited November 1, 201610 yr by steven newman Report
November 1, 201610 yr comment_82104 37 minutes ago, steven newman said: EOD? Explosive, Ordinance, Disposal? I seem to think the Dungeon Shop would qualify as the messiest shop around......but, there are some days.. That this happens Hey...shavings happen.... Is that the same work bench where the Auger book was born? Looks brand new in this picture. Herb Report
November 2, 201610 yr comment_82131 One of the guys I worked with always started the day in his hobby car shop by putting tools where they belong and cleaning the shop. I though it was kinda weird at the time. Then I took my car to be repaired to a local shop. This guy had a multiple garages at his home and the place was immaculate. No grease, no junk and nothing out of place. When I picked up my car, even thought he had several jobs going, it still looked the same. I still think it is very unusual to see a work area so clean and organized. I always start a project with a clean, organized shop. It goes down hill from there, although I do try to clean each morning some before I continue. Other times, well.........You know Report
November 2, 201610 yr Popular Post comment_82172 SIL has a sign in her family room: "A CLEAN HOUSE IS THE SIGN OF A SICK MIND" Report
November 2, 201610 yr Author comment_82220 13 hours ago, Ron Altier said: One of the guys I worked with always started the day in his hobby car shop by putting tools where they belong and cleaning the shop. I though it was kinda weird at the time. Then I took my car to be repaired to a local shop. This guy had a multiple garages at his home and the place was immaculate. No grease, no junk and nothing out of place. When I picked up my car, even thought he had several jobs going, it still looked the same. I still think it is very unusual to see a work area so clean and organized. I always start a project with a clean, organized shop. It goes down hill from there, although I do try to clean each morning some before I continue. Other times, well.........You know I just remembered that a guy that used to work for me had been a Navy airplane mechanic during Vietnam. One of his buddies left a wrench in a jet engine one day. Made a few spits and sparks when the pilot fired it up. A long time ago, I had a muffler put on. I noticed a couple of days later something was hanging down, so on the way home from work, I stopped in the shop. The mechanic that worked on my car thanked me, he'd left a socket and universal joint on the muffler. If I'd been a day later, he would have bought a new one from $nap-On driver. Report
November 2, 201610 yr comment_82230 1 hour ago, kmealy said: I just remembered that a guy that used to work for me had been a Navy airplane mechanic during Vietnam. One of his buddies left a wrench in a jet engine one day. Made a few spits and sparks when the pilot fired it up. A long time ago, I had a muffler put on. I noticed a couple of days later something was hanging down, so on the way home from work, I stopped in the shop. The mechanic that worked on my car thanked me, he'd left a socket and universal joint on the muffler. If I'd been a day later, he would have bought a new one from $nap-On driver. This makes a lot of sense with all of that equipment there. I do not really know what it is, but I can only imagine what would happen is something was left in the machine, similar to the airplane mechanic. This is a quick "Did I pick up everything?" check Report
November 2, 201610 yr comment_82232 all my workbenches are on wheels. very easy to move if needed. say I want to create more space near one, or combine two into a larger bench, or.....clean the shop! only thing that is not easily moved is the table saw and the large drill press. Report
November 2, 201610 yr comment_82244 I try to put tools up as I go but as someone else stated sometimes you go into firefighting mode and don't get to it right away. I usually have a few hand tools that I know will be needed repeatedly on a project that will end up staying out. Several of my machines are on mobile bases and will get rolled out of the way as I move through a project. Shop is trashed right now as I haven't done as much woodworking as I have yard projects this year. There has been a large accumulation of crud that needs to find a new home Report
November 2, 201610 yr comment_82245 1 minute ago, Kelso Chris said: I try to put tools up as I go but as someone else stated sometimes you go into firefighting mode and don't get to it right away. I usually have a few hand tools that I know will be needed repeatedly on a project that will end up staying out. Several of my machines are on mobile bases and will get rolled out of the way as I move through a project. Shop is trashed right now as I haven't done as much woodworking as I have yard projects this year. There has been a large accumulation of crud that needs to find a new home I relate to that so we much be "related" Report
November 3, 201610 yr comment_82295 I've got a bench load of things that need put away. Been doing some outdoor projects and then just set everything on the bench to put away. I need to do that soon. Report
November 3, 201610 yr comment_82386 I leave everything were I stopped using it and continue this terrible practice until I can't turn around. Then I clean up. I don't get it. I really expected the Bikini models to pick up after me but those brats have let me down. Report
November 4, 201610 yr comment_82496 12 hours ago, Cliff said: I leave everything were I stopped using it and continue this terrible practice until I can't turn around. Then I clean up. I don't get it. I really expected the Bikini models to pick up after me but those brats have let me down. Cliff they have been over here and I wish you would take them back as I cannot get anything done.....they keep putting everything away and I have to start over. Now what was I doing? Report
November 17, 20197 yr comment_209023 I like putting thing away but years ago I ran out of places to put things... I'm now building my 14th storage building. This gotta stop someday.... Report
November 17, 20197 yr comment_209094 On 10/31/2016 at 12:00 AM, HandyDan said: I don't like to clean up. Happens when I can't find something. When did you sneak in and take a photo of my shop? Could have at least tidied up a little while you were here...…………. Report
