October 13, 201610 yr comment_78687 Old Belsaw motor gave up, so I was given a good used one. I didn't look to see what voltage it is. When I connected it and turned it on, it ran for about 5 seconds and quit. You guessed it: It was 110 V and I plugged it into 220V. Any educated guesses as to what I burned up? Yeah, I know I did something stupid, so lay off of me! Edited November 24, 20178 yr by Ron Dudelston tags added Report
October 13, 201610 yr comment_78688 Well, on the bright side, the motor was free. Years ago, on the farm we had two fuel tanks, diesel and gasoline. Guess which one I used to refuel a diesel tractor. Report
October 13, 201610 yr comment_78690 If the motor does not smell burnt look for an overload type device that is tripped or failed. Very much doubt if it burnt up in 5 seconds. Roly Report
October 13, 201610 yr comment_78691 9 minutes ago, Roly said: If the motor does not smell burnt look for an overload type device that is tripped or failed. Very much doubt if it burnt up in 5 seconds. Roly Good answer! This is probably the case. Report
October 13, 201610 yr comment_78692 You say what 1 hour ago, oldwoodie said: Any educated guesses as to what I burned up? You say burned up. If there was smoke then it is fried. Report
October 13, 201610 yr comment_78707 I hate it when that happens! Like others said, see if there is an overload/thermal cutoff device. Report
October 13, 201610 yr comment_78721 If not overload switch equipped, check capacitor(s)...maybe you got lucky there vs motor windings. Report
October 21, 201610 yr Author comment_80111 I'm going to wire it up for 110 and see what that might do. Thanks! Report
October 21, 201610 yr comment_80118 9 minutes ago, oldwoodie said: I'm going to wire it up for 110 and see what that might do. Thanks! I don't know about the rest of them but I assumed you already did. Report
