August 30, 201610 yr comment_70702 Marked out where I did NOT want rounded over ( in theory, best laid battle plan?) I wasn't to go past that line on the long sides. Short sides I could plane all day long.. Main tool for this sort of thing was just a block plane. Wasn't trying for a perfect half circle, just enough to "break" the edges. I also planed a bit on the bottom of each part.. As there was a few rough spots. Got the two ends done. Tried to plane the longer ones And forgot what that pencil line was for...ooops. Jointed the edge, re-marked the line with a chisel. Needed a better tool to do the stop cuts.. A spokeshave would do the trick. The chisel and mallet made a better mark to work to. A little better? Flipped the part over, jointed the other side. Got both long sides all planed....might as well find a bunch of clamps, and some Elmer's Think I have enough clamps? Somewhere in there, the lid is glued up. let it sit overnight. Found a small packet in the tool well... Brass hinges. Still had the ACE price tag on them. Might give them a try later. About all I can do for a day...always tomorrow, no rush. Report
