April 9, 201610 yr comment_65762 Mr. David Reed Smith has posted a nice how-to-do on making a lathe powered disc sander. As with all of his articles, it is well thought out and easily built. Read it at- http://davidreedsmith.com/Articles/DiscSander/DiscSander.html Report
April 21, 201610 yr comment_65936 Thank you Lew, I need one of these OK, it turns out that this is not what I was looking for, I need a hand held sander for the lathe, I could probably make one though just off the top of my head. Thinking it through and getting the parts,is another matter. Edited April 21, 201610 yr by Charles Nicholls Report
April 21, 201610 yr comment_65948 Charles, I have a small, flexible disk sander that chucks in a drill motor. I use it for sculpted boxes. Think that night work for you? Report
April 21, 201610 yr comment_65949 Yes Gene, that is exactly what I am looking for, In my case, I would turn a handle for the disk to fit into so that while the lathe is on the sander would be using the power of the lathe to do the job Eddie Castelin posted one such thing and I have not found that post again yet Report
April 21, 201610 yr comment_65952 Mine is 5" dia. for stick on disks. The shaft is 1/4" thick and 2 3/4" long. I don't remember where I bought it. Maybe Klingspor. If it's not going to be powered, does it need to be circular? Report
April 21, 201610 yr comment_65957 2 hours ago, Gene Howe said: Mine is 5" dia. for stick on disks. The shaft is 1/4" thick and 2 3/4" long. I don't remember where I bought it. Maybe Klingspor. If it's not going to be powered, does it need to be circular? It should be, simply because the lathe itself will provide the power to turn it. Report
April 21, 201610 yr comment_65965 So, you gotta make a handle that allows the shaft to turn while preventing it from falling out, right? No mean feat, that. I wanna see it when you get it done. For trickier sanding jobs on some of the more weirder band saw boxes, I made a wooden coping saw frame that holds a 1 1/2" strip of cloth backed paper. Would something like that work for you? Report
April 21, 201610 yr comment_65967 50 minutes ago, Gene Howe said: So, you gotta make a handle that allows the shaft to turn while preventing it from falling out, right? No mean feat, that. I wanna see it when you get it done. For trickier sanding jobs on some of the more weirder band saw boxes, I made a wooden coping saw frame that holds a 1 1/2" strip of cloth backed paper. Would something like that work for you? I'm not sure it would Gene, depending on how the frame works, and whether it would allow access to the inside of turned boxes or bowls. Basically yes it would be a sander on a stick. that you could remove from the stick if you wanted to. The one Eddie did had a round magnet (bearing type)embedded in the handle, I'm still looking for that video Edited April 21, 201610 yr by Charles Nicholls Report
April 21, 201610 yr comment_65968 Here we go he had to remove the original so it was remade and reuploaded Report
April 22, 201610 yr comment_65972 Yep no problem and you're welcome guys. My only problem would be drilling the 45 degree angled hole, I can get close enough though since my spindle on the lathe locks. Report
April 22, 201610 yr comment_65990 17 hours ago, lew said: Cool video! Thanks Charles! You bet Lew & Gene Report
