Rockler 3 pc. Silicone Glue Set
I had to swing by Rockler to pick up a gallon of Titebond 3 glue for making cutting boards. While I was there I saw the 3 Piece Silicone Glue Set next to it. I did a quick search on the cell phone and checked out the reviews for it and decided to pick it up. When doing cutting boards you either need to use a brush, roller or your finger to spread the glue. I had used regular brushes and they did not work well and neither dd the roller. So I have just used my finger to spread it which worked good for me. I have to say that the silicon brush works really well, even better than using my finger. I also gave the silicon spreader a try and it worked well as long as it is on a wider and flat surface. It was not as good for the wood strips. But for wider boards it works good. The brush and the spreader spread the glue evenly and then the glue lays smooth. The silicone glue tray would be good for small jobs, but for cutting boards you pretty much have to use the bottle. Once done with the gluing you can just rinse it off and the glue comes out easily, or you can just let it dry and the glue will peel off easily. One complaint that I saw online about letting the glue dry on the brush is that sometimes when you peel the glue off a bristle or two can pull out.
http://www.rockler.com/rockler-3-piece-silicone-glue-application-kit
Edited by Ron Dudelston
tags added
Thanks for the information.
