Refurbbing a Sargent S416 Jack plane
Not sure IF this is woodworking related, but here goes.    From the Meet & Greet in the Dungeon Shop,  three planes were traded for three others.   I get a few "woodies" to work on
A-yup.  Since the one in the middle already had it's iron resharpened in a class at the show, decided to refurb the rest of it.   Wire wheels in the drill press to clean the dirt and rust off, trying the get back to bare metal.   Had a small jar of Dupli-colour Black, the kind you brush on to stone chips in a car's paint job.    Painted the Sargent Lever cap, and set it aside
And, you can see what else needed some work. Got the rest of the parts taken apart, adjuster wheel was part brass, and part steel.   The frog bolt....yes just one, seems the other was awol.   More on that in a bit. The screws, and other metal parts were wire wheeled clean.   The frame was sanded to remove a lot of rust, and feather out what remained of the japanning.   Grabbed the paunt, again
Paint was on the thick side.   Well, maybe I could go out to Lowes ( not a single hardware store in this town) and try to replace the missing frog bolt?   Nope, Lowes did NOT have that size of bolt.   Their wood screws were also all Phillips headed, too.   Well, decided to add a bit of WOW factor to this plane refurb.   Picked up some BRASS screws, and a couple Brass slotted head bolts.   They head a rounded to.  The closest size was 1/4" x 20...got back to the shop, dug up a tap wrench, and a 1/4" x 20 tap.    A drop of 3in1 oil, and spun a few new threads.
Still let the paint dry just a bit longer, a wee bit tacky.    Wire wheel and a LIGHT touch removed the grime/old finish from the handles.   Now was the time to put this back together.
Two wood screws through the frame into the sanded down base.  Then a LONG woodscrew through the knob.   Brass bolts to attach the frog.   So far all connectors are brass.   The brass wheel and a Steel bolt were added to the frog, with a drop of oil on their threads.  Rear handle and it bolt was next.   While attaching the frog in pace, I used an old iron to get the frog and the wooden bed coplanar.   Set up a test track, again
Not too bad, for a Jack plane.  While I was down there today, I sharpened up the iron on a Ohio Tool Co. jack plane.    Same width iron, but a BIG wood body.   Cleaned the wedge, chipbreaker was cleaned, and nated tothe iron.   Iron was nice and sharp, all rust removed.   Test track was still sitting there, so...
Still need to refinish the wood on it, but, it do work like it should.   Two down, one to go.
  • 2 weeks later...
Apparently, this is a Sargent made #3416 from about 1890s or so.    Branded as a Fulton, and might have been sold at Sears & Roebuck...
Added some bling to this one.    Had to flatten the sole on it too.    Seems to do a decent job, now.
One of these days,....I might, just might, get the hang of doing this sort of thing.....Maybe?
