September 28, 201412 yr comment_55066 Have a smallish backsaw, nothing really fancy about it. Plain jane handle. Spline was a powder-coat black. Pressed in wheat thingys. And....VERY DULL. Was just going to toss it out. Happen to scrape some of the black off the spline......"Made in West Germany" Ok, might see what I could do to make it a bit more useful in the shop.. Tenon Saw! They cost a bunch anymore. Most have fancy, exotic wood handles, too. Maybe, IF I could file them DULL teeth as rip style...... Two piece of pine/fir/spruce ( not sure which) to clamp onto the plate. A couple "C" clamps to keep them there. Clamp the whole mess into the leg vise, with it's brand new leather grab-pad. Ok, saw ain't going to move, or vibrate away. next, a file. Got out the skinniest triangle file I could find. Hard to hold onto with these old fingers. Had an old cobbled up plane tote. Hadn't drilled it for anything....so a small hole was made just for that file. Saw sitting in the leg vise was a might too low to stand and file more than a couple teeth. But, since ToolChest #1 is sitting in the area, it made a perfectly good place to place my rearend on. First step: I got out a BIG flat file, one that was as long as the saw. A few strokes towards the toe ( away from the handle) to level the playing field. Called Jointing the blade. Then just a matter of sitting down and filing away Finally got to the heel of the saw. ( Later found out I had missed two teeth) Time to take it out and try it out. Piece of 2x4 scrap as a standin for a tenon job. Cutting a cheek on a tenon. Saw cuts fast! and a bit rough. Shoulder planes can clean that up, anyway. Had a pine board, about 1/4" too wide to make a tray for Tool Chest #2. Hmm, try the "New& Improved saw on it? As long as the Dummy running the saw holds it right, it will cut a straight line...FAST. A few passes with the plane will be all that is needed. A look at the file holder, the finished West German Tenon Saw, and that 1/4" thick strip it had sawn off. Had so much "fun" I went and hand filed that 18" Craftsman Mitresaw. Also filed as a rip. It will take the place of the fine-toothed Craftsman 22" mitresaw. Tried the "New&Improved" 18" saw in the mitre box......almost smooth as glass IN the cut, but a bit rough at the exit point. Might need a backer strip... Maybe later today, that twins will get a looksee and might even sharpen the duller one. Larger teeth, so might be easier on the eyes? 8ppi is better to see than 15ppi... Report
