Who's got what in their shop
Shane are those 9"x9" floor tiles?
  • Replies 78
  • Views 23.7k
I can't out do Shane's gorgeous restorations, so I won't show any pics, except the scrollie....
1927 Anderson Bandsaw Company 14" Improved Bandsaw
1931 Delta 3110 Polishing Arbor
1937 Heston & Anderson Decoflake 14" Bandsaw
1938 Walker Turner model 900 15" Drill Press with Ships Wheel
1941 Delta Model 1440 Scroll Saw w/ Variable Speed Pulley
1941 Walker Turner model 900-D950 15" Bench top Drill Press
1949 Boice-Crane model 200 Friction Matic Wet tool and Knife grinder
1949 Southbend 9A-644Z Lathe
1953 Delta Homecraft model 28-110 10" bandsaw
1953 Delta 36-400 Variable Speed 12/16" Gap Bed Lathe
1956 Walker Turner 3331 16" Wood/Metal Variable Speed Industrial Bandsaw
195X Burke #4 Hand Miller Horizontal Milling Machine
1964 Walker Turner/Rockwell 15-146 15" VS6 Variable Speed Drill Press
1965 Delta Rockwell model 28-380 14" wood/metal bandsaw w/enclosed base and retactable casters
196X State B4 Oscillating Spindle Sander
1972 Rockwell Model 31-710 Combination 6" Belt, 12" Disk Sander on enclosed steel base
1972 Rockwell Model 37-220 6" Jointer on Enclosed Steel Stand
1979 Rockwell model 15-655 VS6 15" Variable Speed Drill press w/LVC
1985 Craftsman model 113.198611 10" Radial Arm Saw
1987 Delta model 34-802 Unisaw w/52" unifence & table, uniguard, and LVC
Ahh come on Dan, it isn't about out doing, we just love to see these wonderful pieces of equipment. Shane put his out there so show us yours.
I'm new here so hi guys.I have several "old" machines,my favorite is a crescent universal woodworker.It has a 14" table saw,26" bandsaw,8" jointer,horizontal borer and a shaper.I use a crescent #2 table saw alot and a mattison 274 cutoff saw.
I have a 1954 Craftsman Accura Arm 100 Radial Arm saw that was bought specifically to build some kitchen cabinets to replace the two steel cabinets that were installed when we had the house built in 1953, right after we got married.
I still have it and it still runs very well.  Here are some images of the cabinets I built in 1954.  These were take back in 2005 when we revisited the old home town of Erie, PA.  We now live in East Central Iowa since 1969.
They are made from Birch plywood and I purposely used the "B" side because of the contrastin grain.  I was 23 years old then.  Gawd..
Will never part with the old RAS..
Larry
Larry, you did a fine job. I love the grain. You must have made them well, as they are still there when you went back. Now if only we could get as nice of plywood today....bob
I second that motion!
DougB442 said:
Ok, here goes:
I'll begin with the derelicts.
1919 Yates G-2 ripsaw
ca. 1910 Fay & Egan Victor #6 pattern lathe freshly dug out of the ground:
ca. 1910 Falls Machine Co. edge jointer:
ca. 1890 J. A. Fay dowel machine:
Now for the stuff that's either running, or ready to run:
1884 Rowley & Hermance "Sweepstakes" planer matcher
ca. 1910's American #1 tablesaw with horizontal mortiser, Greenlee 226 mortiser behind it:
ca. 1890 Jos. O. Colladay 4 head sticker/molder:
1880's S. K. Lovewell 24" drum sander:
Ca. 1890 J. A. Fay 36" bandsaw:
ca. 1920 Fay & Egan lightning 453 stroke sander:
1880's C. O. & A. D. Porter lathe:
Pre 1902 Dodds 12 spindle dovetail machine:
ca. 1890 L. S. Colburn scroll saw:
1890's Greaves & Klusman 16" jointer:
1920's Colladay Machine works tenoner:
1920's Colladay machine works shaper:
Dewalt GE 20" radial arm saw:
ca. 1890 C. O. & A. D. Porter spindle carver:
I'm missing pics for a Blount lathe, but I think that's it.  Didn't realize I had so much.
Eric
Hi Eric,
Thanks for posting these pictures and your shop floor plan has changed since I was up there last Sept.
Thanks ~ Dan
Eric, glad to see ya posting here.
Love the machines, I don't think I have ever seen them posted all at once ... very impressive!!!
You're Sweepstakes is still one of my favorite machines :)
 You asked for pictures...
ning-wt900drillpress-2-54211-87.jpg?widt
ning-bc-1949-200-wetgrinder-2-54211-59.j
(oddly enough, I don't have a picture)
ning-img-0031-54211-78.jpg?width=721
ning-new-048-54211-88.jpg?width=721
ning-img-0004-54211-22.jpg?width=721
HI Doug,
Thanks for the pics as they all look good, but my favorite for the kooooool factor is the 1937 Heston & Anderson Decoflake 14" Bandsaw.........it looks like it was taken off a Buck Rogers space ship or some such thing.......plus they are very rare............
Thanks ~ Dan
Richard said:
The WT band saw runs so smooth and quite it unbelievable.
Richard,
I have about 7 or so bandsaws (mostly WWII or before / 10" and 14"Deltas) currently and have used probably 50 plus types and brands over the years and yes the 36" Yates American and the 36" Olivers and the Tanys and the Northfields are all great, but if I didn't collect Deltas and only had one pick for a bandsaw for a home sized shop my pick would be a 16" Walker Turner metal/woodcutting bandsaw. I had one for 14 years in my last Industrial Tech teaching job that set there and sawed for several hours a week and never had to do much at all to it......man they are a good if not the best mid sized bandsaw ever made in my book and quite a bit better than the vintage 14" Deltas, but I really like the looks of the aforementioned Deltas on the optional art deco cast iron bases. Here are 2 of my 4 cast iron based Delta 14"ers ........one is a metal/woodworking just set for metal and the other is a wood only for this shed and 2 more Delta 14"ers on cast iron bases set up like these for my other shed which I use primarily for woodworking.
ning-g10-54209-86.jpg?width=721
Just great pictures guys and wonderful commentary. Keep it coming.
  • 3 months later...
1953 Oliver 232 table saw
Late 20's Crescent 8" heavy jointer
1962 Delta 1460 lathe
1977 Powermatic 1150 drill press
1968 Delta 14" bandsaw
1932 Delta Specialty 10" bandsaw
1955 Cincinnati 6" grinder
1955 DeWalt MB 8" RAS
1944 Walker Turner 1180B table saw
A new DeWalt 12" lunchbox planer that will one day be replaced with a vintage Powermatic 100 12" planer
Currently in use:
Late 70's Delta/Rockwell 18" wedge bed planer
1959 Oliver 144BD *" jointer.  It is looking for a new home.
1941 Delta HD shaper.
1990 Powermatic PM66.  It is looking for a new home too.
Machines that are almost ready to use:
1880's or earlier unidentified band saw.
1884 Herbert Baker USB
Machines that are waiting to be brought home:
Early American USB
1920's or 30's The Porter Type C 16" jointer.
Few more pictures
Darcy Warner said:
Few more pictures
Got to work on figuring out picture posting here.
Darcy, you can post the pics by clicking on the Photo icon at the top of the tool bar as you write your post, go HERE to see how our photo entry works. Great pics by the way! Your guys are making me very envious, a trait I am not accustomed too until I have seen the old machinery here!
Darcy Warner said:
Darcy Warner said:
Ok, I will try it again.
Wedgebed and Oliver
ning-img-04980006-54202-89.jpg?width=721PM66
ning-img-04970005-54202-64.jpg?width=721
Delta HD
ning-img-05020010-54202-98.jpg?width=721Herbert Baker
ning-img-07530004-54202-47.jpg?width=721Unidentified band saw, the top wheel and other parts were laying else where
ning-img-07240002-54202-83.jpg?width=721American USB
ning-img-05110003-54202-75.jpg?width=721
The Porter
ning-img-0765-54202-74.jpg?width=721
