March 17, 201115 yr comment_48452 At least I think it's new, I don't recall seeing it when I was there last. Monster Jointer and Monster Shaper Report
March 17, 201115 yr comment_48475 Now that is a jointer!! And is that top clean and slick or what??? Report
March 17, 201115 yr comment_48474 yes sir - 3 phase 9 Hp John Morris said: Is that machinery 3 phase Rob? Report
March 17, 201115 yr comment_48473 Tower, this is Ghost Rirder requesting fly by. That's a negitave Ghost Rider. The pattern is full. Report
March 17, 201115 yr Author comment_48472 Greg Coleman said: Tower, this is Ghost Rirder requesting fly by.  That's a negitave Ghost Rider. The pattern is full. Report
March 17, 201115 yr comment_48471 Could use the fence moved in and a guard for the blade by the operator.  But pretty pieces nonetheless!!!!!!!!Greg Coleman said: Tower, this is Ghost Rirder requesting fly by. That's a negitave Ghost Rider. The pattern is full. Report
March 18, 201115 yr comment_48470 It's not really a fence. Did you notice the powerfeeder ? dragon1 said: Could use the fence moved in and a guard for the blade by the operator.  But pretty pieces nonetheless!!!!!!!!Greg Coleman said: Tower, this is Ghost Rirder requesting fly by. That's a negitave Ghost Rider. The pattern is full. Report
March 18, 201115 yr comment_48468 No it is a Tersa Head - Gary Heltemes said: Rob............Is that a Byrd head you have on there????? Report
March 18, 201115 yr comment_48467 If that's not a fence, how are you jointing edges squarely?? Report
March 18, 201115 yr comment_48466 Wow Rob, great setup. Does the powerfeed work ok on a jointer? I have a 12" and always thought about putting a power feed on it, but thought that you lose the control to flatten aboard? Is that 20 or 24" wide? Makes me dribble on the keyboard.... bob Report
March 19, 201115 yr comment_48464 Hi Dragon , I have other machines that edge joint , different saws and a specially set up shaper - way faster for me. dragon1 said: If that's not a fence, how are you jointing edges squarely?? Report
March 19, 201115 yr comment_48463 Bob ,The power feeder is indispensable flat out . A good eye , two swipes with the hand to establish two points and away you go. I keep a dedicated planer right next to the jointer that also helps straightening out the tough ones . This set up is necessary when working in 3-D or millwork that is not flat when finished . Bob Kloes said: Wow Rob, great setup. Does the powerfeed work ok on a jointer? I have a 12" and always thought about putting a power feed on it, but thought that you lose the control to flatten aboard? Is that 20 or 24" wide? Makes me dribble on the keyboard.... bob Report
March 19, 201115 yr comment_48462 The jointer is a Minimax Formula F 2 , 20 inches wide with Comatic Jointmate feeder. Richard McComas said: Wow! Nice stuff. How about some brand names and sizes? Report
March 19, 201115 yr comment_48460 Thanks Rob. Just a slick setup. I understand about having dedicated shapers. I have 5Â and would use more if I had more room. bob Report
March 19, 201115 yr comment_48459 Bob , I have another one on order from SCM that is a pretty good sized machine and it will be here early summer . It is one of the reasons I am expanding the shop. Bob Kloes said: Thanks Rob. Just a slick setup. I understand about having dedicated shapers. I have 5 and would use more if I had more room. bob Report
March 19, 201115 yr comment_48458 Nice machine. I am sure it will see lots of use. The products you do are great. Do you use all water base finish? In California, I suppose you have to. Did you ever try ML Campbell Agualante? Nice stuff too. bob Report
