Showing results for tags 'woodworking machinery'.
  1. I have a very basic question. What makes a machine old? Amongst the old machinery crowd, is there a cut off date? Is there a time period that is the cutoff time frame? I am doing a research project on this, and I would like to have a solid explanation if possible regarding this. If I were to create two categories, one being Old Woodworking Machinery the other Modern Woodworking Machinery What would be the years to determine this? I need the categories to look like the ones below, x = years such as (1902-1959) Old Woodworking Machinery (xxxx-xxxx) Modern Woodworking Machinery (xxxx-xxxx) Or should the categories look like this? Old Woodworking Machinery (Pre-xxxx) Modern Woodworking Machinery (Post-xxxx) Thank you for any help.
