Showing results for tags 'shop shed'.
	You guys have seen what I have to work with shop wise anyways. How ever it was high time that I cleaned up my trash heap inside the shed and make it useable for wood working since I'm enjoying the hobby quite a bit. The dresser and pretty much everything in there will be coming out in some way shape or form. The dresser is getting tossed it was DEFINITELY NOT made to sit outside in the air. I've got the first load to the dump to include a lot of broken tools and stuff that just wont work anymore. Basically its being cleaned out. Not only that the table and two book cases will also more than likely be cut up and tossed in the yard waste bin. I had a bit too much fun with the chainsaw today and I'm glad I bought it because it will come in handy to make everything manageable to fit in the car or in the yard bin. Its a slow process but I just needed to get it done so I can buy more stuff for wood working such as a table saw and a couple of other things maybe even a better and more powerful bandsaw maybe a bench top planer and or jointer in the long run. Once I get this thing cleared out I'll have quite a bit of room in there. Ah yes the other side of the shed is where the lathe is. Its still a disaster right now yes but cleaning it out currently. CAN WE SAY OVER DOING THE SPRING CLEANING... IT NEEDED TO BE DONE.
