Showing results for tags 'marking gauges'.
Have a few Marking Gauges, that need repaired...first one.. A wee bit worn? We have ways.. I'll cut this for length (Maybe..) and plane and spokeshave to fit...drill a hole for the pin/nail The other 2 sitting there? Are Stanley #77s.. They have both a single pin.. Use as a marking gauge,,and.. The other face has 2 pins, one adjustable for the width of a mortise..however.. A few things are missing..which is why there is now a sheet of 0.032" Brass in the shop...the "Handle bar wear plate" I might cut out with a scrollsaw...the other 2 missing parts.. This is the Stanley No.65 SW Gauge...note that brass slide? it is what the thumbscrews tighten down on...instead of digging into the arm of the gauge.. Might try to build a fancy case for the marking gauges... Resaw this Pine down a bit? Along with that sheet of Brass... I picked a few bags of "parts" Might find some use for these....parts is parts... Stay tuned
