Showing results for tags 'hair stick'.
Summer ain't over yet- 94° and heat index a little over 100! Our Patriot Turners- New member @Gordon posted a scary image of a bowl he was turning. Fortunately, the bowl was the only casualty. Check out Gordon's post for more about what happened- @kreisdorph and @User74 added to our "What's Off Your Lathe..." You can catch up on all the images and comments starting here- @AndrewB continues to revamp his shop. He is currently working on his sharpening station. Read more here- @Masonsailor was back at his lathe to finish up his door project. Checkout his post to see what he has made! What’s Coming Up- @Gerald was lucky enough to be able to attend SWAT last week. For those of us stuck at home, Cindy Drozda gave us a video walk about- Cindy is also hosting a Live Tool Talk on Friday August 30- Registration is here- https://streamyard.com/watch/3Ajs9A8vghKr For The Newbies- Considering getting into bowl turning? A very informative video from Craft Supplies USA- Expand Your Horizons- Mike Peace shows us how to turn a Hair Stick- Alan Stratton is still turning out spheres- New Turning Items- There were some new items presented at SWAT. In Cindy's video tour, she gives us a glimpse of some of the items. Everything Else- I hardly every remove my chuck from the lathe. The EWT chuck jaw changes are so fast and no screws to drop. But when I needed to use a sanding pad, the Jacobs chuck require the EWT chuck removal. Enter Rube Goldberg- I wore out one of those angle drill/sanders from Woodturners Wonders. Removed the small chuck from it and made tis jig.- Sanding while the chuck is still in place! I mentioned my brother had back surgery. I've started making a cane. I found a "how-to" by "mmh". Some of you may remember her from "that other" woodworking site where she posted her custom canes. Her how- gave lots of tips and much needed assembly techniques. I got the shaft turned and rough sanded today- The taper is 5/8" over 32" length I discovered my LED, ala Alan Stratton steady rest wouldn't adjust small enough for the small end of the shaft. Had to fall back on my original steady. The old steady had inline skate wheels and the rubber has dried and fallen off, but it worked. Next up will be to form the handle. Finally, from Ron Brown's newsletter- The Argument For Carbide-Tipped Tools I met Craig Jackson around 2008 in Gainesville Georgia at a turning symposium. He was in the very early stages of introducing Easy Wood Tools with their carbide-tipped cutters. Craig is the founder and original owner, he is the “Father” of this category of turning tools. Others made similar tools but they never really caught on. Craig was finally able to make carbide-tipped tools a mainstream product. I got to know Craig over those 4 days and I let him know in no uncertain terms that I thought he was ruining woodturning by promoting scraping tools over traditional high-speed-steel tools that cut wood fibers rather than tear them savagely. We agreed to disagree. Over the next few years, I made a discovery and went from a strong detractor to a strong supporter of carbide-tipped turning tools. There is a fundamental truth that applies to everything in life. If something seems easy people will try it. If it looks difficult, they are less likely to begin at all. Using carbide-tipped scraping tools is easy. Just grab one and go. You don’t have to own a low-speed grinder and an expensive sharpening jig, or take the time to learn how to use it all. You don’t have to know different grinds or the difference between a bowl gouge and a spindle gouge. You don’t have to know about sharpening at all. Craig’s success ultimately led to many more folks being willing to get started in wood-turning because it was so easy. What if it took longer and didn’t give as good a surface finish? They could still turn beautiful pens, pepper mills, bottle stoppers, turned-lidded boxes, bowls, and anything else one can make on a lathe. They were tuners just like everyone else. Many of the folks who started with carbide-tipped tools later went on to acquire High-Speed-Steel tools and the associated sharpening station after all. But if they had not first begun the easy way with carbide-tipped tools and got hooked on turning, they would never have made it to this level. Rather than ruin a whole generation of woodturners, Craig Jackson’s Easy Wood Tools actually increased the number of turners adopting woodturning as a hobby. I saw Craig a few years after our first meeting and apologized for my lack of vision. I thanked him for expanding our membership in the woodturning fraternity. Craig eventually sold Easy Wood Tools and went back to being an expert machinist. Thanks, Craig! My advice is don’t hesitate to start someone out with an inexpensive set of carbide-tipped turning tools. HSS tools can come later. Make it as easy and affordable as possible for them to get started in turning wood. It may well lead to a lifetime of joy in the workshop. I see turning clubs offer free pen turning at public events and they almost universally offer a radiused square carbide-tipped tool to each total novice. And they get excellent results indeed! Safe turning
