Showing results for tags 'garage door'.
Found 2 results
  1. Danl
    Garage door issue
    I have a Genie electric garage door opener which works for 3 days, does not work for 3 days, and then repeats the cycle. The opener system is ~ 20 yrs. old and we have not had any issues until now. The floor eyes/sensors appear to be connected correctly. I looked at the feeder electrical box and found a wire nut which had two wires which had not been twisted and the nut was too large. I twisted the wires and used a smaller nut. The opener when worked again for ~ 3 days. All of this started a few weeks ago when we had the coldest day this season, approx. minus 5-deg. F. When the system is not working the switches on the wall are not lit. Do you have any suggestions? Danl
  2. Pat Meeuwissen
    Garage Doors
    Guys, I have been asked to build a set of swinging garage doors. They will be painted so besides something like cedar or white oak, what choices of lumber would hold up better/best. Of course MONEY is a deterrent, but the opening is a custom size and won't fit a standard door. The existing doors were just glued and nailed from the back, I'm thinking of doing tongue and groove between the boards before glue and adding the bracing?? Thanks for any input.
